Oil Change
Ling Chan Yew
I hv just clock 10k, the service adviser advised to send in for oil change (estimate cost below rm600 ), any advice whether we should do it at 10k for only oil change or flw the on board computer indicator?rgds
Not sure if its direct impact of oil change + service but my car just exceed 6000KM and havent send for service yet. since after 6000KM my fuel indicator stuck at 9.1L/100KM both urban and highway.
Used to be ~8.5L/100KM urban and can go lower to ~6.5L/100KM on highway. Now im thinking to send for service soon
rgds
Which part are you checking ?
Journey computer ?
Or the Overall ?
Overall, you need to reset it for the readings to be accurate .
After awhile, mine was stuck at 13.3 cause i just finished a very spirited drive.
Repump petrol, reset the counter and voila. gettin 9.3 now
Erm.. I find BMW NA engine oil in my E90 N46B20 degrade (turn black and thickening) much faster then my Avanza.
My puny Avanza 1.3L engine despite small CC, I frequent drove it at 4~5k rpm.. for above 140kph cruising, no to mention toll booth shoot outs.. :4:
Few possible reasons I can think of, my E90 is lady driven, frequent short distance compare to my puny Avanza la. That too would contribute to ageing of the BMW engine oil by comparison.
Or is it my Toyota Genuine Fully Synthetic 5w-40 is far more superior than those of Torco, Castrol, Liqui-Moly, 0w-30, 5w-30 and 0w-40 that I've used for my N46B20? At least my 8 years old 220k km old Avanza valve seal still intact and not losing any oil for 10k km oil change interval. The N46 valve seal failed big time, despite less than 6 years old, less than 95k km.
There's one more critical element affecting the ageing of engine oil and that's heat. BMW engine runs a lot hotter than my Avanza engine. Which killed the oil and perhaps my valve seal too..
Now back to F30.. does the engine oil being circulated to the twin scroll turbine for lubricating and cooling purposes like conventional turbo engine? If so, doesn't that automatically means your engine oil fail a lot faster than NA BMW engine? For a Scooby, 6k km is about max you can push the oil change interval. I know some are doing it every 3k km, even that, the difference in engine performance can be felt instantly.
Food for thoughts..
Both bro.. I will try to reset and see how things goes. Thanks anyway
Journey computer ?
Or the Overall ?
