c-square
- Dec 8, 2004
- 2,759
- 38
Traveler;454867 said:So long as the ingredients in the mixture are all above the minimum recommended RON rating of the engine, then there should be no problems. RON95 and RON97 are both above the minimum recommended RON 91 rating for the newer-gen beemers (not sure about the older models, so I dare not say), so no problem what... now if you fill up with mix of RON80 and RON 97 then maybe got problem la (but no such thing as RON80 here now, so why worry?)
My own tank is currently about 90% Shell 95 and 10% V-Power (leftover from previous filling).
Thanks, Traveller.... That's exactly what I was asking. I am now using RON95 as a base/primary fuel and was thinking of supplementing it with a higher RON fuel (like the RON97) hopefully to achieve a better result. Granted it will not be as good as pouring in RON97 entirely but if it is as simple mixing the RON95 with RON97 to achieve say RON96 (if there is such thing), then maybe it is worthwhile to consider mixing the two fuel to get a higher RON than the 95 albeit paying an average cost of RM1.92/litre (ie assuming 50% ROM95 at RM1.80 and 50% RON97 at RM2.05).
Maybe some technical persons/experts with some experience in the oil refining business can further comment or share their thoughts on this.
