rattlesnake1982
- Jan 22, 2012
- 460
- 28
Off topic! Herbert pls ban this Tianci trouble maker lolz
Aku ade bmw lori ko ade?
Geometry;840161 said:Mine is 2011 320d M-sport. All OEM except tyres.
Front struts and absorbers are all checked/replaced and are in good condition. Even engine mounting was replaced.
Tyres are new none run flat. Wheel alignments and balancing are all good.
When I drive it on uneven road (especially on sharp small convex/small dip surface) at above 20km/h, I can hear knocking sound (thumping) from front part of the car. I can feel it under my feet. I suspect the sound is from front absorber shooting out to rest position because I can feel the small bounce from the front wheel.
However, the car has no issue while driving at high speed and cornering. Handling is as good as a BMW.
Is this thumping sound / small bounce from the front wheel normal?
Thank you in advance
Wuk51;840212 said:Check your front brake..tighten all undercarriage. ...last time me also same issue...now no more...
Sent from my GT-N7100 using Tapatalk 4
Wuk51;840317 said:Normally most of it front...like mine the knocking sound coming from front....so they disassemble and assembled back with proper torque wrench. ..
Pez;846988 said:Hi All!!
Maybe someone had asked this before, but appreciate if any sifus can help here. Where do you guys usually sent your 320d when the BSRI is over?? Any advice on any good workshops out there that knows how to treat the car great??
Thanx so much in advance
Geometry;841584 said:SC technician loosen up front struts and assembled back. However, the sound came back few days later. I guess he didn't check the front brake. Would front brake causing part loosing and hence the sound?
Wuk51;847000 said:Possible bro...mine after changing to performance brake the knocking sound totally gone....:stupid:
SilverBullet;847017 said:dah name pun performance brake...sure solve all problem one...cabutzzzz :vroam:
