Do the usual track day routine :
1) Pre-Event checks
a) Make sure the car is in a well maintained condition
(B) Check ALL fluid levels
c) Replace the brake fluid if not changed at service specified interval
d) Check the condition/pressure of all your tyres, Make a note of the
pressures
e) Check your brake pads for condition/thickness, preferably put new fast
road/comp pads such as Pagid Blue pads in, front and rear
f) Remove any accessory's not securely fitted
g) Check the speed rating of your tyres, Make a note of this and never
exceed it on track
h) Remove any floor mats from the drivers footwell
I) Remove the spare tyre if you have secure storage
j) Take some basic tools with you, enough to change brake pads at least
k) Take at least one axle stand for when you change the pads
l) Take some rags/swarfega for cleaning your hands etc
m) Fill up with SUL even on standard spec engine, you wont get more
performance, just gives the engine more protection from detination. If you
run on SUL normally put 1% octane booster in for safety.
n) Take a can of Red Bull, it gives you wings you know!
2) Spares etc to take
a) One set of brake pads at least, front and rear
(B) One 5 litre can of oil
c) Some tape to cover your light lenses
d) A helmet
e) Some thin soled sports shoe's, aids with brake feel
3) Pre-track checks
a) Recheck your tyre pressures, if one is down you may have a slow
puncture which could blow when at high speed
(B) Increase the tyre pressures by 4-6PSI higher than you run on the road
c) Tape up your headlights
d) Ensure you understood the driver briefing, if you are not sure about
any aspect, ask for clarification. Ensure you understood the passing rules
in particular!
e) Drink your can of Red Bull and put on your helmet
4) First lap on every run
a) Never thrash the car on the first lap, speed up gradually bringing the
oil/water temperatures to normal working parameters
(B) Gently bring the brake temperatures up to temperature
c) use this lap to get familiar with your new, rather alien surroundings
d) Try and give yourself space front and rear, don't be tempted to follow
the car in front too closely as you will be concentrating on him/her and
not learning the track
e) Get used to checking your mirror before and after each corner, you will
be amazed how quickly some cars will catch you if you are a track novice.
5) Rest of laps
a) Bring up the speed gradually if you are a novice, you will learn more
(B) Give it Death, remember your there for fun
c) If you experience brake fade/boiling don't think it will go away before
the next corner, slow down, it is very likely to be worse the next time
d) If you feel a power loss coming out of a tight bend back off, don't
keep it planted, you are probably getting the first sign's of fuel surge,
if you keep it planted you are risking detonation due to a week mixture.
return to the pits and refuel. This can happen with half a tank of fuel on
board, don't get fooled into thinking it can't be happening already, it
can.
6) Last lap in
a) Do a slow last lap in
(B) Try to avoid using the brakes at all to give the disks/pads some chance
to cool down
c) Don't stop looking in your mirror, there might be some idiot still on
max attack
7) Entry to pits/stopping
a) Enter the pits slowly, look out for kids/spectators, it is easy to not
hear you coming
(B) DO NOT SWITCH OFF YOUR ENGINE
c) Allow the engine to idle for at least 2 minutes
d) DO NOT PUT THE HANDBRAKE ON OR SIT WITH YOUR FOOT ON THE BRAKE PEDAL.
e) The above is to stop the pads from being destroyed by the heat sink
effect from your red hot brake disks, stop on a level surface or arrange
for someone to chock you wheel.
f) Let everything cool before you check the following
8) Post run checks
a) Check the brake pads for wear
(B) Check ALL fluid levels, You may never use oil on the road, you are
almost guaranteed to do so on a track day run
c) Check your tyre pressures, if one has dropped you may be on the way to a blow out
d) Check the tyres for wear/cuts
e) Check you are still not wearing a silly cheesy grin
Remember, bring the car home in one piece!
