GB for K + D Can USB Cable (INPA compatible)
Status
Not open for further replies.
Jarance,
Can the software that is included with the cable be able to retrieve any live data from my car? [1997 E39 523i SV]
-currently the BMW scanner i bought from you able to check/clear errors, but not able to retrieve any live data.
Since the end of this cable is D type, is there a way where i could convert the D type to 20-pin round type for my car? [OBD located in engine bay]
- C. 20pins to 16pins adaptor....is this the converter that i need? How much is this?
I surely will place my name in the GB if only it can be used for my car.
Thanks bro.
bimmerholic;641824 said:
Jarance,
Thanks bro.
Jarance probably is out for the day already so let me get the question for him.
Your second question first, yes that is the converter that you need to convert 20 pin to 16 pin D type connector. Each for rm10
Your first question, I can't say for sure but it probably will since INPA is a factory grade debug tool. The interface can also be used with modified GT1 software which is normally used by our local workshop to debug/program our cars.
Cheers
Cheers
Thanks aidilj for the prompt reply. I appreciate it. :D
As for the converter, can i use the one i already have that i bought during the BMW Scanner GB? Is it the same?
I'm glad there's a possibility of me to stand a chance to retrieve live data. However, there's a "silly" question i need to ask- shouldn't there be a reader/scanner/programmer (for ex: the BMW Scanner 1.4.0) for this cable to connect to?...or is it the case of simply installing the necessary softwares off the DVD and plugging in the cable and voila???....somethin like that?
cheers.
cheers.
Yes you can use the converter you already have, they are the same.
Yes there will be acompanying software included, it will be called INPA. INPA is more advanced and not as user-friendly as the BMW scanner 1.4.0 software
Head over to some of my threads for further reading
http://www.bmwclubmalaysia.com/forums/showthread.php?40618-EasyDIS-44-and-INPA-working
http://www.bmwclubmalaysia.com/foru...S-Activating-recirculated-air-memory-function
http://www.bmwclubmalaysia.com/forums/showthread.php?41073-DIY-E46-OBC-stalk-retrofit
Cheers
Jarance,
Thanks bro.
Bro we are at the same situation on getting to read our live data since the 1st 1.4.0 scanner we bought can't read it. Don't know how about this 2nd GB on K+D Cab Cable(INPA Compatable) will work or not.
LOL......just go for 2nd round GB for this K+D Cab Cable(INPA Compatable) since it was not so expensive if compare to the real GTI scanner which easily will cost u few thousand i think.
Wish us good luck on this 2nd GB for the live data purpose
cheers.
Q: As for the converter, can i use the one i already have that i bought during the BMW Scanner GB? Is it the same?
A: yes, it is the same. The 16pins to 20 pins converter is universal regardless of type of scanner that you use. Most BMW manufactured after 2001/2002
come with 16 pins connectors only.
From 1996 till 1998 (e36 era), some of the rides have 20 pins connector at the engine bay and 16 pins
inside the car.
Note: if you have both connectors, it will make no difference where you connect the scanner as they are wired in parallel.
Q: I'm glad there's a possibility of me to stand a chance to retrieve live data. However, there's a "silly" question i need to ask- shouldn't there be a reader/scanner/programmer (for ex: the BMW Scanner 1.4.0) for this cable to connect to?...or is it the case of simply installing the necessary softwares off the DVD and plugging in the cable and voila???....somethin like that?
A: The BMW Scanner 1.4.0 is developed by a 3rd party company. In theory, live data should be available for all BMW model. But unfortunately,
it is available for certain model. I guess the programmer/developer of the program did not have enough information or source code to enable
the function for ALL the model.
Unlike INPA and GT1, these programs were initially developed by BMW to cater for all known models. It was hacked and modified by a group of people to enable it
to run on a window/UNIX based PC. However, being a "old" program developed for 16 bits computer, it have some issued to run
on computer that are 64 bits platform.
alex, come and see me at PD and we will try the INPA on your car. if can, then you buy lor. No need to guess.
neohkw;641803 said:
A. K+DCan USB Cable (RM240)
1. EL118
2. B33MER
3. B33MER friend
4. e39-boy
5. seewai - TT self collect
6. Solo + RM10 for poslaju to Kuching, Sarawak
7. m3addict
8. ichi82 (self collect)
9. azeL_Inc + RM10 for poslaju
10. Rubes72
11. Yazmeen
12. TheTaj (self collect)
13. Alex5522 +RM10 pos laju
14. Neoh + RM10 pos laju
B. BMW Scanner 1.4.0 (RM170)
1. Aidil + RM10 for poslaju
2. EL118
3. m3addict
4. Mtigo
5. Petrus + Poslaju to Sabah
6. TheTaj (self collect)
1. EL118
2. Mtigo
3. Petrus
4. TheTaj (self collect)
Note : the GB will closed when the item reaches 20 pcs or 8th June (whichever comes first).
Thanks guys, the target quantity have been reached. I think we can proceed with the ordering of the item.
Payment instruction will be advised via PM soon..
ps.. I noticed most of you going for the K+Dcan USB cable have also purchased the bmw scanner 1.4.0.
Most probably will see a second hand sales of the scan 1.4.0 soon on the forum.. LOL
Anyway, thanks guys for the support.. especially to aidil and iandaddy for introducing (racun) me to the INPA and GT1.
Likewise, I'm glad that we're successful in racuning you. Also, thanks for organizing the group buy for INPA interface.
One thing to clarify is that, I've no problem running INPA and GT1 on my 64bit Win7. Hope we can streamline the installation steps for all GB participants later.
Cheers
Cheers
The installation step comes in the 2.6 GB DVD. It have even a video to teach you on the setup.
DIS-55 already setup for Vware. Just need to run the Vware and evoke the program.
BTW, i found out that the Gt1/Dis-55 run a bit faster when you allocate more RAM memory to VWare.
I think about 2GB instead of the recommended 780 MB.
btw, how did you managed to run the NCS expert on the Win 7-64 bits platform?
1. EL118
2. B33MER
3. B33MER friend
4. e39-boy
7. m3addict
10. Rubes72
11. Yazmeen
2. EL118
3. m3addict
4. Mtigo
7. m3addict fren
8. m3addict fren
C. 20pins to 16pins adaptor (rm10 as per 1st post)
1. EL118
2. Mtigo
3. Petrus
5. m3addict
6. m3addict fren
7. m3addict fren
Cheers
converter/adapter only rm10?
Yes, allocating more RAM will make DIS run faster as discussed in the "INPA working" thread.
Last I remember yes I got it working but nothing on the GUI make sense. Let me check if this is installed on the 64bit machine or its on virtualized XP machine..
adpator is RM10. here is the actual thing. One side goes to the scanner module and the other side
goes to diagnostic port in the engine bay.
Waa...thank you so much bro for your kind of service offer to me :love: (Test first if works then only buy)
Anyway is fine for me and im fully trust u & bro aildilj this will works. Just proceed to order it, btw i did google some of the info about this tool too.
Pls pm me the payment details for me to bank in 2u.
I will see u at PD in case i don't know how to install the INPA Program when received the stuff.
Ya one Q, Did this INPA program works on Win XP or Win 7 ultimate 32- bit ?
Thanks again.
Thanks again.
INPA should work will in win XP and I have got INPA working in Win7-64 bits Home Edition laptop.
So, most probably should work in Win 7 - 32 bits ultimate.
Thanks again.
Afraid now since you quoted me..
Did a little search and seems that even E36 you can get live data in INPA
http://www.bmwland.co.uk/forums/viewtopic.php?f=4&t=120117
This is for 1998 E39
http://forum.bmw5.co.uk/viewtopic.php?f=11&t=46724
another one
http://forums.bimmerforums.com/forum/showthread.php?t=1511127
Cheers guys
OK guys. The group buy is officially "closed". I have PM all concerned the payment instruction via PM.
if you have not receive the PM, please let me know and I will forward it to you.
The order shall be placed once all payments have been received.
For last minute order, I can still squeeze you in provided the order have NOT been placed.
p/s.. not sure whether my paypal or credit card will be busted due to this order.
oh my...im too late for this...can i still buy this BMW Scanner 1.4.0?if yes,can mr jarance give me the details?many thanks :)
Status
