GB for K + D Can USB Cable (INPA compatible)
Status
Not open for further replies.
Thanks Jarance for organizing this one. Cheers!
A. K+DCan USB Cable (RM240)
1. EL118
2. B33MER
3. B33MER friend
4.
5.
B. BMW Scanner 1.4.0 (RM170)
1. Aidil + RM10 for poslaju
2. EL118
3. m3addict
4. Mtigo
5.
C. 20pins to 16pins adaptor
1. EL118
2. Mtigo
3.
1. EL118
2. B33MER
3. B33MER friend
4.
5.
2. EL118
3. m3addict
4. Mtigo
5. Petrus + Poslaju to Sabah
1. EL118
2. Mtigo
3. Petrus
1. EL118
2. B33MER
3. B33MER friend
4. e39-boy
5.
2. EL118
3. m3addict
4. Mtigo
1. EL118
2. Mtigo
3. Petrus
seewai;640499 said:
Bro, what's the difference between BMW Scanner 1.40 and K+DCan USB Cable? If I've already a BMW Scanner 1.40 for my E39, what additional benefits/features do I get from K+DCan USB Cable?
Appreciate your guidance.
Cheers.
seewai
The problem with scanner 1.4.0 is that not all bmw can be scanned and have live data. This is due to the limitation of the program.
It was written and tested for "certain" model. However, the developer did not get fully covered all modules.
with the EDIABAS, you can opt to run GT1 (emulate mode) or INPA. Both of these program are developed by "BMW" and covered
all models and most modules. The programs have been hacked to enable it to run on a PC.
So far, I managed to run INPA which is window based. Setup is a bit of a hassle but there are online step by step instruction.
Since it is an "old" program, certain program like NCS expert (for coding) cannot run on my 64bits win7 as it a 16bits program.
I do my coding using the scanner 1.4.0 and watch live data on the INPA.
Since INPA have more LIVE data, it will help the user to analyse the car better. However, for those who are not familiar with
the engine or other module function, it will be just meaningless numbers on a computer screen.
Based on the feedback of the scanner, some of the guys car do not have any display of live data.
Plus INPA or GT1 can communicate with the gearbox system in which scanner 1.4 is unable to and in my case it allows me to perform SMG adaptation, bleed out the system and run diagnostic checks. It goes deeper into the system than the scanner 1.4 from what i've seen.
1. EL118
2. B33MER
3. B33MER friend
4. e39-boy
5. seewai - TT self collect
2. EL118
3. m3addict
4. Mtigo
1. EL118
2. Mtigo
3. Petrus
1. EL118
2. B33MER
3. B33MER friend
4. e39-boy
6. Solo
2. EL118
3. m3addict
4. Mtigo
1. EL118
2. Mtigo
3. Petrus
Salut
Solo, yeah your journey for live data should end with the K + kDCAN interface :top:
That's why I'm biting the bullet and buying it. Still wondering if should let go my BMW Scanner 1.4.0. What do you think? To keep or not to keep, that is the question.
Salut
jarance;640437 said:
e39-boy, what up? going to the next level?
nolah.. just for the sake of having it, still have more to learn :)
aidilj;639526 said:
current set
Left is EDIABAS/INPA interface, right is ELM327, offset is the USB-to-serial
Bro aidilj, I have the same laptop hehehe. I thought at first that was my photo, I took a similar photo with my BMW Scanner 1.36 some time ago.
Bro Jarance, this cable GB always laku one! Must not let Kastam know...
haywire, kastam people know lar. all good comes in with CN22 declaration. I have download all the coding
and use the proper code that have minimize duties and tax.
btw, I test the scanner 1.4 on hakamee Z4/M54B25 and there is no live data available.
when I use the INPA with the KCan cable, the live data is available.
Salut
solo, I think you need me to send to you via poslaju or you are planning to come to KL.. LOL
Salut
Good question, I recommend that you keep scanner 1.4.0. Some of the similar function of INPA or GT1 are much easily done with the scanner.. That is what I'm doing as well. Cheers
I know for awhile already since seeing the picture in your Aegean thread. But mine no blu ray..
When I purchased the BMW Scanner 1.4.0, shipped from China, the invoice I received is printed "Computer sample cable", value "US$10.00". That's for 1 unit though.
That's usually the case. Here's a quote normally given by China seller
"We will try our best to get our customer’s their order “duty-free”."
1. EL118
2. B33MER
3. B33MER friend
4. e39-boy
6. Solo
7. m3addict
2. EL118
3. m3addict
4. Mtigo
1. EL118
2. Mtigo
3. Petrus
Salut
Status
