Check this web page. Driver upto Window10. Scroll down until you see the "Window" driver.sewell said:do we have any latest win 10 driver for our scanner?
Are you referring to the ELM327? They are generic for all OBD-II compliance vehicle.Rick1 said:Hi,
Has anybody used torque pro on an Android and connected to a bluetooth car connection? If so, any good? I want to review any codes that my car may have but dont want to pay 150rm for someone to tell me.
Thanks for your kind feedback
jarance said:Are you referring to the ELM327? They are generic for all OBD-II compliance vehicle.
Now they are cheap. Cost less than RM20 from China online.
Easy to use if you only want to check for error code. Bluetooth connection is straight forward. Just pair it.
Note: but to reconnect after sometime is a hazard. need to unpair and then pair it again.
Free download on Google play store for Torque but have to pay for other apps.
Just to remind anyone thinking about these. They are good but DO NOT leave them plugged in overnight. I cannot explain how such a small device managed it but it flattened my battery :-(Alex5522 said:
Did you pair the ELM327 with your phone?digilife said:Thank Thread Starter for this Great Thread.
:77: :77:
However I bought this & it seems that I was not able to connect to my car system to do the diagnostic.
elm327.jpg![]()
Could it be that mine is faulty ?
It look like you have connection to the bluetooth but not the ECU.digilife said:My screenshot-ed it when I tried out that day.
Pls help me to understand it.
From your experience which is the best type of connection , via Bluetooth , via WiFi or Cable ?jarance said:It look like you have connection to the bluetooth but not the ECU.
Try it with another car like Toyota Vios or any car that have OBD-II plug. if same problem encounter, then problem is the ELM327.
The ELM327 is just a generic tool for general cars. Torque fuction is very limited. Just scan for error for the ECU and reset alarm. It does not look at other module and hence the function is very limited.digilife said:From your experience which is the best type of connection , via Bluetooth , via WiFi or Cable ?
I believe it should be cable rite ?
If my hunch is true, can you recommend me a good cable. I dun mind using a laptop or tablet as long I can do diagnostic & clear simple faults
Thanks
