Calvin Tan
Senior Member
- Dec 9, 2004
- 726
Alvin said:Calvin
Ya i'm a bit dumb. Didnt study much. Just shows how smart a person u are. Cheers to u mate.
You started it "small kid"!
Alvin said:Calvin
Jerman;189485 said:Albundy,Funfer,Bailey,
I just love all of you guys. I just posted an innocent topic ie ECU re-mapping vs Piggyback chip and...........I ended up "changing a car"???
Thanks guys!
p/s: Calvin got a point............even those Evo/Subaru owners with their powerful machines still do mods, mah?
In today's world, there is never enough, yes?
Daniel;195119 said:Jerman, BS aside.
Here is the real deal.
Remapping your ECU or Piggybacking will only give you a temporary solution to your quest for more power. Its not a long term answer.
Why?
Because the BMW ecu is too smart for its own good. Overtime, it will 'relearn' and recalibibrate itself to counter for the new air/fuel/igniction map which your chip/piggyback has introduced.
Unless.
Your piggyback/chip had a manual override to prevent that from happening.
Why?
Unless.
ALBundy;195128 said:Half yes, half no.
When the ECU is in close loop (meaning to say, readings from the O2 sensor are used by the ECU --> iteration process), what you said is right. The iteration process will continue until the ECU finds the optimum settings, which is the pre-determined settings by the manufacturer. In other words, the "cheating" process by the piggyback will sort of wear off in due time, where it will be rendered useless.
HOWEVER, when you floor your accelerator OR when you rev past 3000rpm (sometimes 3500rpm, depending on which model), the ECU will revert to an open loop system where there is no iteration process and the "cheating" process by the piggyback ECU is effective.
The other way is to run an open loop system, of which I am currently doing so.![]()
Both system will have its drawbacks. The better way would be to dyno tune the car and save the new mapping in an eprom and install it on the original ECU. Likewise for OBD2 cars, flash the new mapping (obtained through dyno) directly into the ECU. Heard this is possible now but not in Msia yet.
Daniel;195523 said:Bundy,
Yes i have a Apexi Select SAFC installed. It doesn't allow for a manual bypass, thus the problem I am having now.![]()
I need another type of Piggyback.
About the disconnecting of the batt, the piggyback has flash memory, so i as refering to the main ecu.
Daniel;203074 said:Chips i do not believe in it. Piggyback, yes it works, and i have the dyno printout to prove it.
XXX;203250 said:so my unichip how? every once a while have to sent back to bluff ECU again?
