E90 parts & maintenance
Hi guys... What the code number Colour for Alphine white? my car is e90 320d 2011 need to repaint bcoz it has deep stratched under my side skirt so need to repaint the whole side skirt, thanks!
You can check it online using your VIN number. Here's the link http://bimmer.work/
Done, bro Nabilishes my colour code number for Alphine white is Alpinweiss III(300)..thanks you bro Nabilishes
Please advice,
I just 2nd tried the E90, I feel the acceleration abit delay when the car totally stop and full press the accelerator
The explanation from salesman:
When the fuel almost empty, it will limit the fuel supply and cause the car less power.
It's correct ?
And if Plug coils and valvetronic happening, computer will appear ?
Sent from my iPhone using Tapatalk
Please advice,
It's correct ?
All sifus,im seeking for some advise:
Currently owe a 2007 E90 n I presume is a N46 engine n having water leakage problem now. Sent to a workshop to diagnose. According to the mechanic the bolts inside the engine r broken n cause the water leak out. The mechanic gave two options:
1. Drill a bigger hole to replace the bigger size of the bolts. Cheaper n is around 2k to 3k. But not sure can sustain for how long?
2. Change another secondhand engine. But it costs about 10k to 12k. Is it worth to do?
Is there another 3rd option for me?
get another opinion bro.. take the car to a different mechanic and see what they will say. You will get a different reason/solution and a different price. then decide
Thanks bro azal33 n bro gendong. Unfortunately they already dismantle the engine. Don't think can shift to another workshop.
My heart with you bro..
that is the workshop way of holding you from the "balls". Now you have no escape but to fix with them at their price.
Happened to me once that my E90 was leaking oil from the oil filter cap, the shop forced me to change the cap itself @ RM220. Later i found out that he could change the seal only that comes with the filter and shouldn't cost more than RM30.
Up to date, i DIY everything in my house. Buy spare parts from Bavarian Auto Parts and fix at home.
All Sifu,
I facing a funny issue on my light system,
Hi-beam not functioning, but I tried to take out the bulb and check, it's working
And the left side body signal light become brake indication light [emoji27]
Please help
Chronicle88 said:
All Sifu,
Please help
Sounds like a wiring malfunction. You might want to take your ride to a specialist and get it checked.
Hi I'm new to this forum..I'm planning to buy 325i msport 2007 model from direct owner. Owner hv full service record and the car in good condition..
Is that a good idea to buy a 2007 model with mileage around 120k...
Thanks in advance, cheers
Sent from my SM-A500F using Tapatalk
Just to share recent maintenance:
Parts bought from BA
1. Water/Coolant Pump (BMW): RM1820.00
2. Thermostat (OEM): RM215
3. Coolant 2x Bottles: RM35 per bottle
4. Labour: DIY
Total (incl 6% GST): 2231.30
Hey Guys,
Just to share a recent maintenance of my E90 325i LCI...
1. Replaced rear window rubber seal. Bought from BA and DIY at home. Thanks to Bro Moots for his tips. :rock: Damage: RM240.
2. Replaced transmission heat exchanger with the air cooled type (Brand: Hayden). Damage: RM 700. Did the conversion in BlueGreen.
3. Replaced valve cover gasket, valvetronic motor gasket and valvetronic sensor flange gasket. Damage: RM356.
4. Replaced engine oil (Liqui Moly Toptec 5W-40 6.5l) and added Liqui Moly Ceratec Damage: RM490.
5. Replaced wiper blades. Bought from BA and DIY at home. Damage: RM85.
6. Replaced tires (Conti Max Contact on all 4 wheels - non RFT). Front: 225/40/R18. Back: 255/35/R18. Damage: Around 2300.
Black_Sunday said:
Hey Guys,
can please advice which workshop you go recently? would like to change item 2 & 3 soon.
Thanks
Thanks
There are a few workshops that does such kind of conversion. A few to name - BlueGreen Motor Werks, M-Speed USJ, RGB Motor Works Puchong, Herritage...
Hi, i seldom post but here goes -
Owned the 330i since end 2016 and done about 12k KM to date. top up twice (1 lit) Castro Edge inbetween the 10k KM. Battery changed to DIN100 last oct - delkor.
Servicing done last month which consists of -
Castrol Edge+filter
Valve cover gasket (minor leaks)
1 coil busted
Main belt
Power steering reservoir cap gasket (nasty leak)
BC Racing V1
Motorsports Hardware stud conversion
Next 2 months prolly new tires front and rear and also ordered a waterpump kit.
Did the muffler delete - blardee regret, gonna put back in an aftermarket muffler soon. Too loud for me.
Other than that, very very happy with the ride so far.
