bala8282;659108 said:Hai , I am Bala using ori 525msport u.k spec. I am curious to know whether the telephone function can be activated by using any type of interface cable ?
Thanks
aoch88;660579 said:Front brake pad (OEM) = RM190
Front brake sensor = RM50
Labour = RM50
Total damage = RM290
r37720;660621 said:No need to change rotor kah?
My rule of thumb : 2x change the pad with 1 rotor. Ratio 2:1 pad: rotor.
Grand;662759 said:Only one prob remains. The active steering's fault sign ("active steering initialising...") keeps coming up, say about once in 3 engine starts. Though it will eventually disappear after about 3 min of driving, it is still pretty annoying.
Meanwhile have to endure the sweet and nice warning bell when the active steering sign appears to greet me.
Grand;662759 said:Recent damage on my E60:-
1 set of rear brake pad (ATE brand) RM190.00
1 pc of rear disc pad sensor RM65.00
1 pc of Battery GP RM450.00
1 pc of radiator cap (the rubber lining at the cover of the ori cap was broken) RM75.00
The ori BMW battery was changed although it was functioning though the cranking sound when starting engine is getting longer. Beside some of the electronic gremlins are beginning to show up eg. power window sign. So to be safe and sure, better change to a new one. The new battery was not registered. Only have to reset the date and time and re-initialise the active steering as per the manual. Other data like saved radio stations etc are all intact. No more electronic gremlins with the new battery.
Went to check with a mechanic who advised me to leave my car with him so that he can bring his computer to the alignment shop to do a proper re-alignment before recommending other more expensive remedies like changing the active steering control unit or the steering angle sensor. But couldn't find time to leave my car whole day for him to test the alignment. Meanwhile have to endure the sweet and nice warning bell when the active steering sign appears to greet me.
Peter Sauber;662824 said:Hi Bro Grand
The battery is that cheap? Or am i wrong because i read many times in this forum it cost like RM1k plus?? Please let me know. THanks..
aoch88;662909 said:I think there are a few types of battery. Those AGM ones would cost you RM1K+. Someone please correct me if I'm wrong![]()
GMENG;664907 said:When I was on the way back from Kuatan last Tuesday, my E60 engine flashed the "over-heated" msg and was asked to stop the car immediately by the i-drive. After 15 minutes cooling off, I could re-start my car without any incidence. Called Auto Bavaria Glenmarie and they asked to send the car in for inspection. Since they were busy, I put my car there overnight last evening. Got the update abt noon time that I have to change the Radiator Water pump and the thermostat plus the coolant. The mechanic estimated the costs will be abt RM3700. Any advice on this?
aoch88;664909 said:Bro I suggest you to get a list of parts which they ask you to change and cross check the price with Bavarian Auto or some other parts dealer. If it's somewhere around there then it's fine but if it's way off then better discuss again with your mechanic. Some of these mechanic likes to mark up parts prices like there's no tomorrow.
GMENG;664914 said:Thanks aoch88. AutoBavaria is always very high compared to others.
I've checked with Apex (recommended by AbuHasan earlier) the pump was at RM1500, coolant RM41. Didn't get thermostat yet. Anybody got similar parts changed?
aoch88;664918 said:You got the number for Apex? I'm talking about Bavarian Auto, not Auto Bavaria![]()
GMENG;664929 said:Sorry, it's Autopex (not Apex) Tel:03-5513 9663. Autopex qtd RM1500 for the pump with installation. Qtd also the shock absorber (Bagio or something) RM500+ with installation
bavarian Auto quoted me RM1366 for pump and RM220 for thermostat. Qtd also the shock absorber RM500. they are stockist only.
