desbimmer;605626 said:Heard a soft gurgle of somewhat loose metal being shaken in a container when I was warming down my car after a drive - only today as I make it a habit to listen to my car every now and then. Did not like it and immediately sent it for a diagnose. Boss of the shop let me 'listen' to the problem which was the water pump. I also asked about the burning smell when I drive somewhat like a speed demon when on the highway and he said to change the gasket as well. Have yet to test if that was the culprit but I do trust him and his knowledge a lot. Also asked him about the 'click' sound every time I turn off my engine and he said it was normal. Seeing that I was skeptical, he let me listen to the other two 5 series in the shop and true enough it is a common sound! hehehe....I always tot it was a problem... Job well done.
1. Water pump - RM365
2. Radiator Coolant @ RM38 each (4 bottles) - RM152
3. Valve Cover Gasket - RM110
4. Valve Cover grommet @ 15 x RM5 - RM75
5. Labour Charge - RM160
Serviced at Mechanikar, Tmn Mayang
affan66;638571 said:makan pasir month:
1. Radiator (BEHR) - found a leak - RM950
2. Gearbox oil sump + filter - RM480
3. Ori brake pads (front) - RM550
4. Ori brake discs (front) - RM960 (RM480/ea)
5. Windscreen washer pump - RM105
6. Coolant + ATF (6 liters)
excludes labour.
Done at MRoadster, Pandan Indah....
arggghhh
desbimmer;638381 said:Hi bro! Best get the opinion of the mech for the lub on valve cover. Tell tale sign will be the burning smell when you rev your car. As for air con belt I have not changed mine yet so I can't give you an estimate.
eric2000;638714 said:ok. will check with the mech 2moro.
yesterday screen showed "tyre punctured", luckily just came out from hiway. so, quickly drove to my friend's tyre shop and change all 4 tyres to new Mich PS3. (RM2480)...:102:
azmanshah;649378 said:Adding to da statistic
Done ATF change at German Mechanic in Desa View, Melawati
ATF=RM350
Pan/filter:RM320
labour : RM150
Diagnose/error reset : RM80
golf7109;634707 said:i think if u all want to save, u can buy directly from the bavarian, the spark plug only Rm20, but the mech will charge u RM32min - 6 pieces, the spark plug coil only RM80 each but the mech charge u RM180 - 6 pieces, thermostat RM150 each but the mech charge u RM185-RM200. So, actually I felt cheated by my mech after calling the bavarian to check out the price, on top of the part which he charge extra expensive he also charge for labour..I paid extra of RM800 and labor another RM80. Next time, I will go to another workshop and ask them how much they charge for labor only and i will buy those parts myself, of course pls don't let the mech to dismantle yet. hope those mechanics out there don't cut BM owner throat la..
mashboiler;652056 said:E60 parts changed at Kuantan
1. Electric water pump - RM1600
2. Thermostat - RM250
3. Coolant - RM40
5. Labour - RM160 (inclusive wash)
dzuljazz2001;652088 said::listen: I will speak with the mechanic for a small discount bro. I believe the EWP is a bit on a high side. Hopefully he will obliged :4:
azmanshah;656320 said:Done service on my car. Bot several item from Bavarian Auto Part:
1) Genuine BMW motor engine oil 5w40 Long life = RM35 x 7 = RM245
2) Oil Filter = RM35
3) Air Filter = RM64
4) Bosch Spark Plug = RM19 x 6 = 114
total RM458
Service by German Mechanic Desa View, Melawati.
Labour Charge RM60 +
Handling charges for part from outside : RM22
