E60 parts & maintenance
Hey Guys,
Car couldn't start and changed to new batt but same problem and my regular mech traced it to faulty Engine ECU. Got the car back after replacing the ECU and reprogramming. This morning same problem ie car couldn't start at all. Gonna send it back to the workshop.
Anyone here had this issue?
cheers and stay safe !!
forgot to mention, the car was leaking current and thats why the new batt was dead, overnight.
When u changed battery, did the mechanic registered the new battery bro? It has to be registered, as if u dont, the ECU might think it is still on the old battery, hence it would not be charging properly.
But a new batt to be depleted overnite? hmmmm...... do u hv any other 3rd party mods? dash cam? android headunit, etc?
It just happened. did nothing to the car. batt is registered
Hi guys, my e60 523i facing steering vibration issue when braking on high speed, I suspect is because of worn front lower arm and caster arm.
Is it okay to use OEM brand for these parts? Bavarian auto quoted me original rm550 per pcs, while only rm190 for German oem brand (Euste), quite a big difference
Braking vibration is usually due to warped/worn discs, have you checked them?
So I have got my front brake disc and pad changed, ori bmw parts. Haven't got chance to test on highway yet...
Front brake disc ori rm320 per pcs, rm640 for 2 pcs
Front brake pad ori rm430 per set
Labour charges rm80
Total damages rm1150
Labour charges rm80
Now all ok??
Hi E60 lovers.
Just bought a 2005 e60 523i from my KL client, mileage at 62k only. I am from up north but am looking for a reliable mechanic in PJ or KL as the car is in the klang valley.
Recommendations please as:
1. The "rear brake pad change" warning light has appeared;
2. The audio system goes on and off as I drive;
3. The tires are 7 years old and need a change.
Thanks in advance.
Hi E60 lovers.
Thanks in advance.
could try pkl motorsports (mr lai)
Block B, G-25, Jalan Kuchai Maju 2, Kuchai Lama, 58200 Kuala Lumpur, Federal Territory.
