E60 parts & maintenance
golf7109;840089 said:
Thanks Terry. Where u changed it. What model is your car? Mine is E60 M54engine so there is no switch.
Mine is e46. I am using a new mechanic now in kuchai Lana recommended by a guru here. They are very good. Maybe u can call them to check price but they only use new part. If new part above budget, maybe u buy part yourself from the chop chop shop list in the e46 forum and ask them to install. Ask him if he is ok with that. If u want contact pls pm me
Today change wear n tear mechanism items as below:
1. Rear absorber boge normal, 450 x2
2. Damper 40x2
3. Mounting 65x2
4. Wishbone big arm 275 x2
5. Wishbone small arm 260 x 2
6. Front absorber mounting 85 x 2
6. Rear bearing 145x1
7. Labour to change bearing 120
8. Labour to change absorber & wishbone 300
Total damage 2,770 (excluding alignment cost)...
2. Damper 40x2
3. Mounting 65x2
could you share the workshop name?
Was away for a while and car wouldn't start when I got back.
Managed to jumpstart, but saw the battery was almost 3 years old, decided to change.
Went to Optimum.
Also did oil change while I was there.
The gasket cover was leaking oil and they changed the aircond belt as well.
Costs are total
Oil Filter 38.60
Valve cover gasket set 187
Valve cover rubber seals 15 units 93
Battery Din 100 Bosch 680
Air cond belt 56
Mobil 1 1.75 units 381.50
Inspection Service 80
Renew Valve cover gasket 120
Total 1648.10
Went to Optimum.
Costs are total
Oil Filter 38.60
Air cond belt 56
Total 1648.10
The price you paid for valve cover gasket and rubber seals seem high. FYI, my valve cover is leaking as well and I just bought them both for RM115 from Bavarian Auto. Thinking to diy the gasket and also the vanos seals which I bought from group buy a while back.
Was quoted RM 2300 for E60 today at Puchong:
1-front absorber-quoted at RM 800 per piece
2.Absorber cover
3.Mounting
4.Labour.
I think quite high...
2.Absorber cover
3.Mounting
4.Labour.
I think quite high...[/QUOTE
Boge Msport front absorber is 750 each,
Mounting is 75 each
Damper is 40 each,
Just absorber + accessories for front, total should be 1730.00
2300-1730, labour = 570???:motz:
Don't forget the alignment too....
2.Absorber cover
3.Mounting
4.Labour.
Mounting is 75 each
Damper is 40 each,
Thanks ...looks like it..today another shop quote me for m sport absorber at Rm1240 per pcs.
2.Absorber cover
3.Mounting
4.Labour.
yeah its high. i changed bosch msport rear absorbers and total cost me RM1730..
Changing my absorber tomorrow
Boge front -RM470 per pcs x 2
Damper,cover and mounting- RM 170
Labour -RM 120
Balancing and Alignment- RM80.
Labour -RM 120
The absorber price is very well rated, where did u get it?
just serviced my car at Euro Tech Motorsports @ Kota Damansara.
1. Castro Edge 5w40 - RM215 per 4 litre x 2
2. Wiper motor & rubber - RM150
3. Labour - RM50
Jansufian;846316 said:
Got it from bavarian auto subang
Bro.. where do you fix it and mind to share? not many worksyop willing to do this if we bring our own parts
cg;829127 said:
http://my.simapages.com/SSG-Car-Cooler-34015.html
My took less than 2 hours as the compressor no need to removed to change the control value. It should takes longer time if compressor need to be remove.
Advise to go early as this place quite busy especially on Sat.
Went to this shop early yesterday morning. Very professional service that Mr. Chew guy. Change the control valve, vacuum, refill gas, labor. All in RM650. Work done in abt 2 1/2 hours.
Other shops I asked, even autobahn sunway, all wanna straight away change compressor and wanna charge me kaw2.
I would recommend any E60 owners whose experiencing the same A/C problem to go to his shop. His number is 0192402151 - Mr. Chew. And thanks for the tip bro CG
Good things must share. That's what makes this forum so popular : )
- - - Updated - - -
Hie All Sifu's , any recommended workshop in Johor area JB / KLG or BP .
