E60 parts & maintenance
Hi Maxlim, can you give the adress for the garage you service your car or contact person so that I can get the details from him??
Hi All,
Driver side rear window failed at open position (cable broke). Decided to also change all my suspension at the same time. Found 3 with leaks and bouncy drive.
Joyful Spending
4 suspension - front and back with all cover (boot) and mounting - Boge for M-sport (SGD 1500 ~ RM 3600)
power window lifter - SGD 130 ~ RM 312
Workmanship RM 400
Car drives totally different... Old suspension was totally out... :)
Cheers,
JoeKG777;678481 said:
Hi All,
Workmanship RM 400
Cheers,
JoeKG,
Many thanks for sharing. What was your milage when your shock absorbers gave up on you? TQ
Does anyone knows how many bushes are there on the steering rack, front suspension system, etc? I was wondering if changing these would give better driving experience.
i am experiencing my front wheel sound like " clok clok clok" or Nut losing sound once over uneven road. It it caused by lower arm bushes "kaput"
Any ideas to get rid of it ?? many thnx
Most probably the ball joint in the lower arm is worn out and it is non replaceable. Get Lemfoder for replacement and not any other brand.
Hi Jerman.
I bought my car March this year with a mileage of 160k. When I changed last week my mileage was already close to 190k. I was told that this was the original suspension and was never changed by previous owner... Car is an early 2007 version...
Herbert, how much roughly for the replacement ?
Hi bro,
Want to ask about wheel bearing..
Anyone here changed front wheel bearing?
How much is the cost?
Where should i go? Tyre shop or workshop?
Tq
Suggest you call Bavarian Auto (03) 7876-5555 and give them your VIN number. Tell them you want the price for Lemfoder.
Engine oil 5w-40 7 liter + Oil Filter + Labour = RM400.00
Fender Signal Cover + Labour = RM130.00
Symptom: Engine fault message lighted up. One of the cyl misfired causing the car to run sluggishly. Changed all 6 ignition coils at RM130 each. So total RM780.00.
Change front brake pad (ori BMW) at RM430.00 and brake sensor at RM55.00
Waah interesting price...... Can I know the place of the wshop......
What brand of oil r u using
Thanks in advance broo....
bro,
Mspeed at USJ.
ROWE Hightec-Lubricants Made In Germany.
No problem bro...
Hie all
Does anybody know y my car have a "!" sign on the side of the gear indicator panel..
Weird coz although i put my handbrake off the sign is still there..
Thanks in advance sifus
I got the same 'sign' too on my other car. I think i needs to be computer checked. I got it checked by AB during that time.
wang;681586 said:
bro,
Mspeed at USJ.
No problem bro...
Hi bro
did the wshop done any diagnostic on ur UDM
lisma;681863 said:
Hi bro
Bro, my car running smooth & no any fault msg at the moment,so the boss said no need to diagnostic...if really want diagnostic then will foc for regular customer also...hehe
wts pu e60 spoiler just rm400
pls call 010-3666575 for more info this spoiler made of PU is only rm400
Just change some parts for my E60
Rear brake pad Rm280 for 2 pairs
Alignment and balancing Rm70
Rear brake sensor Rm65
Two new tyre Rm1060
Adjust rear camber Rm120
Total have spent RM1590 ~ dont know whether is it expensive but i love the feel after doing this^_^
