E60 523i AB 2007 My Adventure Continue
I send my car to Bomin Auto for repair jobs.
After diagnosis my radiator,termostat, termostat hose and elelectrical water pump still in good shape
only below item in picture have leaks and small cracks.
same photo angle at previosly i spoted the coolant leaks..... now its clean... and peace of mind....
this major radiator services and parts change including wind screen pump with strainer at Bomin cost me below bills
Using ori bmw parts
wow.the return hose(the longest hose) weli the expensive at rm400..
and the vent hose veli the skinny osso mahal at rm 200
but wat to do....BMW mah...
looks like the n52 is slightly different than the m54 as my vent hose is completely hidden under the large metal plate at the top.
yup....peace of mind....priceless...
Last weekend found my left rear tyre makan dalam very bad. Other 3 tyre still in good running conditions. Feedback from few friend suggested to check the rear link arms. Maybe one of the damaged. How evel last year I have change both lower arm the longer and bend one.
Some history of both rear tyre. Tyre brand Archilles ATR Sport 245/40/R18. I changed on 28 Sept 2013 and I have cover 47K Km. As I'm remember, I naver do any aligmnet on my car, because it's drive straight even after changed suspension and lower arm. Only doing couple of wheel ballancing.
Suprizingly both front tyre still okay. Brand new when I purchase this car (change by the car dealer). Brand YOKOHAMA S drive 245/40/R18 made in JAPAN
For this tyre changed I did it at Shah Alam Tyre (Jeff King of Rims). Few BMWCM members also go to this shop as well
Old tyre come out from my car
rear right tyre (driver side) - Still can be use, but better I change both...
rear left (the damage one)
Manufactured date stamp week 19 year 2015
Manufactured recommended price is RM988 per pc
The mechanic at this shop said to me, they only can know and sure if any my rear damage from aligement machine reading. But physically we cannot found any bushing damage or any lower arm loose.
Car at aligment amchine and doing setup for tyre aligment.
Aligment data before adjustment.
Aligment data after adjustment. Camber adjusted as well.
I do not know how to interpret the data. But the mechanic said now more balance left and right. Left rear wheel angle also reduce.
I hope this time, this tyre not makan dalam lagi..
So now the interesting part... how much damage to my pocket? The tyre I get good offer only RM580 per pc including balancing compared with manufactured recommended retail price of RM988.
The rest you guys can look at below disclose repair bil.
Total RM1508.40
Good price for 245/40/18 tires. Do give feedback on this tire performance.
Update on service and repair bil... total cost can make me demam
1. Oil filter HEG profile gasket 2pcs RM170
2. Labour for oil filter HEG profile gasket replacement RM120
3. Lubricant servce RM45
4. Oil filter ori BMW 1pc RM75
5. Revnol 5W40 7l RM381
6. RR control upper arm (left and right) 2pcs RM600
7. RR lower arm (left and right) 2pcs RM900
8. Replacment of rear arm RM120
9. Rear Bulb 12VW16W 1pc RM5
10.Rear Bulb (single LEG) Big 12V21W 1pc RM5
11.To replace Front Brake discs and pads RM120
12.To check huming sound (waste money no conclusion where the humming sound come from) RM80
13.To check petrol smell and replace fuel filter RM65
14.Front brake disk Zimmermann 2pcs RM600
15.Front brake pad - ORI BMW 1set RM500
16.Front brake sensor 1set RM55
17.Fuel filter with level sensor - VDO 1pc RM380
18.Aligment / chamber adjustment front & rear RM50
Total RM4271
Total with 6%GST RM4527.26
