samueltong;811688 said:
Wow is that gb ned replace afta 200k mil?
Riding on bmw scary man....but some of major service wont get heart attack la....main just
Gb scary lo
It depends on how you take care of it, your driving style etc..mine clocks 240k kms and it is still running alright..dont worry so much lah bro..hehee
Gb scary lo
Worst case scenario Gbox overhaul is only 6 to 7k only for a 5 speed tiptronic BMW. You go and ask Japs car GB overhaul cost la then u know how cheap and good is German engineering
hi.
my e39 hav shown engine,abs,asg n gb lights..ive made my way to mspeed to fix the error..this is wat ive repaired.
1) ABS control module (labour,encoding & troubleshooting) RM1800.00
2) Front ABS sensor & labour 2pc RM560.00
3) Rear ABS sensor & labour 2pc RM600
4) Ignition coil 5pcs & labour RM 600.00
5) Spark plug & labour RM 150.00
6) Accelerator Cable & labour RM 100.00
Total damage RM 3810.00 Less 60.00 = RM3750.00
so hows the bill issit reasonable or else.But my engine light still on n my engine shacking sometimes n transmission not that smooth...ah meng said thats bcoz of the air leak n sum others faulty...but thatone i said next time repair...coz dun have anymore money to spend...huhuhu..
eau-rouge;813665 said:
number 2 - 6 diy would be much cheaper
I wonder how do you guys have the confident on making diy attempts especially with mechanical items? I do understand that there are some vids & threads online to assist. But being not so lucky with diy myself, what do you think ppl like myself should look for first, but mostly to gain the confidence.
u just need to know a bit about car to realize some of them are actually talking nonsense. next, if u go to fix something and they end up breaking other things in your car and to add more salt to the wound they even charge u to replace the broken things they did just like my case it is really a PITA.
Hence, your suggestion is, its better for you to try and experiment first. If trial becomes an error, then seek for assistance? Wouldnt that be super expensive then? Being in such a desperate situation, I am sure the mech would slaughter you with "ridonculous" price!
its not as difficult as you might think..some mechs are scaring you for them to cari makan
try it bro, its worth it
Sure bro.. I'm sure lots of buddies here are at willing to assist and sharing advises.
"Saya budak baru belajar, kalau salah tolong tunjukkan". :eek:
don't simply try la. first need to read/watch and learn how to do. with some guts and appropriate tools u then start to diy. i am not saying workshops are bad all the time, maybe just some times and we are unfortunate to be there at that time & place. go if you are comfortable with them and stop if you are not.
not only here bro. a very good thing about bmw community it is so global. just google "how to bla3" then many handy links will surface. bmw parts themselves are not that expensive if compared to other japs makes. i know because i owned a civic before. it becomes expensive only if you get it through workshops.
front brake disc(pair) - BREMBO ............rm 212
front brake pads(pair) - JURID...............rm 126
front brake pad wear sensor..................rm 25
all at BAV auto USJ
DIY.....
all at BAV auto USJ
DIY.....
Moots,
That is a very good price for a pair of Brembo front disc rotor. Where is it manufactured & do give us your feedback after you had your usual run-in.
View attachment 29681View attachment 29682
Herbert;815420 said:
Moots,
well....Wong mentioned german oem.....but not stamped on the disc except BREMBO .all packed in brembo red box with instructions and all.got disc wear indicator dimple summore.so far so good.however,the jurid pads are dusting quite a bit...
hi every body if you wish to know or check bmw parts please call me 0122967887 . sure very good price... tq.
Hi All,
Battery went kaput yesterday (century DIN88L).
Replaced with Yuasa DIN100L which cost me RM460.00.
Thanks
i replaced mine for rm120 DIY in march 2011.plastic impeller as well.i was chasing a coolant leak around that area and i thought it was the pump but it was not.turned out to be the plastic thermostat cover which had a small crack.
i removed a totally good pump due to this....metal impeller summore....
My Service from workshop 1
Mobil 1 Fully Sync 5w-50 (175 x 2) = 350
Oil Filter = 45
ATF BMW Original 1 Quart (46 x 6) = 276
ATF Gasket pan = 95
Spark plugs (Bosch) (14 x 6) = 84
Wiper Tank replacement (labour only) = 50
Other labour charges = 110
Total = RM 1010
What you guys think ?
care to share...
1)Body weather strip driver side rm215...
2)Actuator door fuel lid rm140...
3)Inlet pipe rm75...
4)Water pipe rm190...
5)Coolant rm30...
All parts bought at BA SS2...:top:
