E38 self levering
yup.. can with a litle brain from teh mechanics.. but most wont do it as they do not understand what is the accumulator doing. It is just a precharge of 155 bar of nitrogen rubber bladder in a steel ball.
thanks alan.
something technical .........am still learning........:top: :listen:
Thanks Vincent, Alan. and sorry for late reply AAM.
E38 acu. I bought new RM440 each (oem), but for the original one B.A told me its more than double!
AAM, I have new one installed but I am still work on it because problem still not solve so might have to wait untill problem settle. and Its only a pair needed for the rear system.
Dear sifu :confused::confused::confused::confused::confused::confused::confused::confused::confused: how??? down to the point its there any body got any more golden experian to share regarding this system solution!!
Regarding E38 bumpy ride feel!!! (especially at the rear)
Dear sifu, please tell me If I have over look anything!!!
(www.e38.org was being study from day one and more than one time)
JOb been done:-
1-use E38 specified/indicated fluid to flush and bleed the system accordingly, (few time, few specified location).
2-clean, service and even replace the levering control valve, (swap with other menber with system ok E38)
3-replace brand new (oem) accumulator (pair)
4-adjustment was done with the ride sit on the ground accordingly. (high, medium or low was the same feeling)
5-GT one scan was ok with no falt code.
Going to or should I check also:-(how to?)
1-main fluid preassure pump in the front engine compartment?
2-rear suspention?
3-S-EDC switches or any other switches affected?
4-any main control module affected?
5-will the speed controler module affect the ride feel? What to do?
6-will the rear brake light sensor affect the ride feel? what to do?
WHAT ELES missing in the mission?
Kenny, my knowledge on the SLS is limited. However a friend of mine (DIYer) is quite an expert with the SLS of the Mercedes Benz. He even taught our MB specialist on how to repair the system. I believe both MB or BMW SLS are similar in design and how it works.
If you really can't get it resolved, maybe you can bring the car to KL and I will ask him to see how he could be of help or you can give him (NPK) a call 0193102880 Just mention my name & I am sure he will render whatever assistance you need.
BTW in the course of his business he travels to Johor every now and then. Anyway just give him a call lah.
