Herbert
Well-Known Member
- Sep 8, 2009
- 4,443
- 83
ah_Keng;602785 said:Sifus,
My car is 1996 528, where do I locate the connector?
Inside the engine compartment....you will see a 20 pin round connector.
herbert;602934 said:The PA Soft diagnostic tool can detect all error codes plus erase them. Can even monitor all live data when engine is turn-on.
jarance;602939 said:herbert, thanks.. so far any problem with the diagnostic tool?
bmw7833;603015 said:List is growing..
Have to careful with duty tax.
Bro, ask the seller to declare the code correctly while send out the parcel.
jarance;603020 said:I think the tax cannot be avoid if the item are greater than 1 item. When I got mine, there was no tax as 1 item is
considered for personal use.
wonder what is the code.
1. computer part
2. car accessory
which one would be lower?
BTW, your E39 do NOT required any adapter. they are plug in directly to the diagnostic port which
is located in your car. it located just under the dashboard on the right hand side (just under the small
compartment). Just pull down the flap and you be able to the d-shape plug.
1. computer part
2. car accessory
aidilj;603023 said:To get package through with no hassle get them to fill up and paste CN22 custom declaration. This would make the package "dilepaskan" easier. Based on my experience getting parts. And ask them not to put description hinting for vehicle use.
Cheers
