redlotus;603328 said:BTW, your E39 do NOT required any adapter. they are plug in directly to the diagnostic port which
is located in your car. it located just under the dashboard on the right hand side (just under the small
compartment). Just pull down the flap and you be able to the d-shape plug.
Bro Jarance, any idea if it can run on Apple OS though?... And can you tweak ur ECU with this? Agreed though, best left to the experts...
I doubt it can run under MAC OS. Suggest that you have dual boot (Mac & WIn XP) to overcome your problem if you intend
to use this program. This goes for Vista and Win7 as well. Even though the program might work, the driver for the USB port may
not be available hence render the program useless.
No, you cannot tweak the ECU. This is not a ECU tuning unit. Those that are available cost thousands and need to have proper
training, re-tune map (remap) to tweak the ecu.
Please use this tool for the basic function to understand your car better and to diagnose your error code.
Leave the rectification work to the expert/workshop.
