aoch88;733366 said:My pleasure to help bossBtw, he can also consider getting those CKD 523i LCI which is going around his budget (RM170-190K). The LCI engine on 523i produces more or less the same horse power (190bhp) as pre facelift 525i. Literally you can say the LCI 523i = pre-LCI 525i in terms of engine performance. After that, spend a bit of money buying the BMS Powerbox and you will have a fun and spirited driving.
cafee;735279 said:Power loss /jerk/misfire - car age about 20 months -corrected with piezo replacement -
Major Noh;735312 said:Broaoch88 I am totally ignorant about whether my e60 is n53 or what ever, just bought it becoz I just love bm, its design & now performance, been with MB Kompressor for many years, bought an e60 msport uk spec registered in 2006, manufactured in 2005, just 3 months ago and enjoying my driving now, but I am not sure whether mine is LCI with n53 engine. but it seems to need engine oil top-up at least 2x between 10k mileage. I will certainly want to catch up and belanja u TT to learn from you on this e60 beast!. hope to hear from u. thanks.
aoch88;735387 said:Thanks for the feedback. Actually I spend a lot of time going to the workshop where my friend works (they deal with BMW, Mercedes, Audi, VW, etc). There are indeed problems with N53 but there are just as much with N52's as wellIf the injector is faulty, the engine check light will come up. If you're talking about "fuel mixture too lean" error code which contributes to jerking, the culprit is the top engine cover (there is a ventilation valve built inside). Replacing that would resolve the issue. BMW also has a recall campaign for the Piezo injectors and you can know if yours is the latest revision based on the part number.
Yo boss, yours should be N52 engine because N53 only exists for LCI models (year 2007 and above). The N52 is well known for such engine oil issues. What viscosity oil are you using? It would be good if you use thicker viscosity oil like 10W - 40W or 15W - 40W whereby it could potentially reduce/solve the missing engine oil problem.
Major Noh;735433 said:Yo Bro aoch88, thank you very much for lesson 1, at least am aware that my engine is n52 and of course I can agree with you and it make sense that I should use higher viscosity oil as your thoughtful & wise suggestion. Am using 5w - 15w currently, always have 1 lit standby waiting for signal for topping up. Am learning slowly, thanks bro.
aoch88;735506 said:No worries boss and it's my pleasureI would be more than happy to share my knowledge and I hope you have a pleasant experience with your new BMW
aoch88;735426 said:I think it's not about the model but more towards the engineUK specs F10 are also N53.
TheTaj;735732 said:What engine oil did you use, and what viscosity, may i ask? Would like to try what u are using.
t2ribena;735711 said:if your e60 is manufactured prior to Sept 2005, then your car should have the M54Bx engine...
Major Noh;735757 said:Hi t2ribena, based on the registration card, it states (on the engine #: XXXXXXXXN52BXXAF) so I believe its N52 as informed by aoch88. Mine is a recond uk spec 525i Msport, and the registration date in UK is 2006, but once a mechanic show me from his computer Registered :2005. So probably its manufactured after Sept 2005 but before Jan 2006 in Germany. Anyway thanks for the input.
aoch88;735795 said:A few ways to check what is your engine type:
1. M54 engine is black cover while N52 is silver top cover. Example of N52 engine:
2. Look at your windscreen (passenger side lower end corner) and take down the last 5 digit. This is your car's VIN code (some sort of serial number). You can then use the number to check online to give you more details about the car.
Not all N52 has the engine oil dissapearing issue and here are some articles about this known issue. Hope it helps.
http://www.google.com.my/#hl=en&scl...or.r_gc.r_pw.r_qf.,cf.osb&fp=97d6bef60b710d35
It's definitely a widely discussed topic even in this forum so happy reading, haha.
paultantk;736599 said:
aoch88;736520 said:My pleasure Major Noh to helpI hope the information is useful.
