TECHNICAL SPECIFICATIONS - BMW 320i
Body BMW 320i E46, 4 doors
Engine 6-cylinder in line, longitudinally installed; distribution: 2 overhead camshafts, 24 valves; displacement: 1993 cc; bore x stroke: 80.05 x 66 mm; compression ration: 11:1; maximum output: 275 bhp @ 8800 rpm; maximum torque: 230 nm @ 7000 rpm; engine management: BMW Motorsport Ecu 12A; lubrication: wet sump
Transmission rear-wheel-drive; gearbox: BMW H-pattern, 5-speed with straight cut gears and dog engagement; clutch: carbon single disc; differential: mechanical limited-slip differential
Chassis front suspension: McPherson strut, coil springs, gas-filled dampers and anti-roll bar; rear suspension: central link arm with double wishbone, coil springs, gas-filled dampers and anti-roll bar; steering: power assisted rack and pinion
Brakes power assisted dual-circuit system; front: 4-piston calipers, 332 mm steel ventilated discs; rear: 2-piston calipers, 280 mm steel ventilated discs
Dimensions length: 4490 mm; width: 1809 mm; wheelbase: 2742 mm; weight: 1140 kg including driver
