my e39 wiper wash failed to spray water since few weeks ago. 1s suspect is d pump. my dablevanos has ony 1 wiper wash pump. located at the front tyre rear compartment. to access u need to remove d tyre first then remove d splash cover. u can refer to moots posting n picture. d pump failed to work. suspect some dirt/debries entered d pump as some of the waterhose(blackplastic) becum brittle over time and dissentigrate. i knock d pump few times on d floorfew times, refit back, wlao.. its works again :top:. next i oso change the blackhose to transparent fishtank plastic pipe. tied d joint wit cabletie to secure the joint. refit back everything and smile, cheap fix :top:
