Which e39 to get?
I think those 3 models share common problem la.. no particular problem to one model.. i guess..
Btw im no sifu... just thru my reading n observation..
Sent from my GT-N7100 using Xparent Green Tapatalk 2
my e39 2.5 averages about rm1k/month in wear&tear items, excluding the itchybackside items ;) this is not that bad comparing to the rm700/month i used to spend on my old bluebird :D the handling and comfort is bestest :)
After every wear n tear items/parts have been replace don't think need to spend extra just minor hear n there...
My engne almost done..
My meter cluster done..
Headlamp done...
Rooflining done...
So basically normal fast moving items need to monitor during daily use...
Fuuhhhh I 'm not a sifu either just a newbie also...
Aku ada stereng lori....ko adaaa....
Which e39 to get?
alantiong;831010 said:
yiukeng.. for whatever money you will have to pay for the car.. do allocate 4-5K to change all rubber hoses, pcv, expansion tank, windscreen seal, bottom covers for peace of mind.. this is essential. forget about anything else first.
then two months later after you recover the initial shock... spend another 1.5k for front upper and lower arms, rear upper and lower arms.
next month.. you will be calling up hay wire to fix your pixel at cluster panel.. and the mid panel.. RM500 and lots of teh tarik..
next.. you will calling up yazmeen to polish your head lights and getting the LED ring.. RM500.. again lots of teh tarik
if you are lucky to have a car that already have a decent after market suspension, then you dun have to spend more on it. otherwise.. 3K for that..
by 6 months.. itchy backside.. look for M5 rims.. plus tyres.. 6K.. then look front .. back.. left and right.. eh.. M5 bodykit missing.. $4K with painting
after that.. hmmm when you were at the rims.. you realised the rotors and brake pads about time.. go KL teamco.. get brembo set.. RM600 per pair rotor + RM385 for front pads... + RM50 for lining sensors + 100 for labour..
one day you go convoy with club member to genting sempah.. suddenly aircon not cold.. then found out regulator burns off .. RM300 and since at it.. might want to check the rest of AC...
after one year.. you will have broken seat side panel.. 500 per pair... and then roof lining suddenly come down like broadway.. rm900
all in all.. if you love ur 39.. at present all cars are at least 10 years .. and you will spend 15-20K extra in the first year to do it up..
bro.. i have done 2 39s.. and this is the common expenses.. we all get sucked in.. anyone tell you any less.. just trying to racun you without telling you the absolute truth!
its fun . .its expensive.. but better than orgasm!!
Very comprehensive for e39 ordinary maintenance list bro, I have done most of it except the bbk...
But u missed out 1 thing, which is very popular also... After u collect the car went for service and change to some fresh engine oil... Drive that for about a month, a fine day when u reach home, turn off aircon n HU, n finally, turn the key.. Then "DING", u look at the dashboard..the popular "CHECK ENGINE OIL" came up..
After that, u will start to hear n see this more often and often and toping up engine oil more often...
Time for the valve sealed change.... Might cost few gran for that....
Last but not least, change the GB oil for peace of mind...
Yes you are right bro...
Tat why the servive record is very important so tat we know when is the last service done...
I'm quite lucky cox the owner just change gb fluid n axle oil...
The 1st I did is change engne oil n filter n air filter...
Hi mick123, excluding regular service, wear & tear parts cost 1k/month is a lot money. Is this common to all 525? maybe i should stay away from 525 since it really need a deep pocket
It's still a car that's >10 years old. Hence, wear and tear plus some sort of maintenance is still required/expected. That's the reason why it's best to find a E39 with proper service records which you will know which parts have been replaced, how long they still can last and only focus on certain parts which still yet to be replaced, which can save you some $.
Even my 528 averages about that amount. You don't spend every month but every now and then you get a hefty bill.
Sent from my GT-I9300 using Tapatalk 2
Hi bro...
Just replace my suspenssion since the last time change was 5yrs ago so its high time to change...rm1k++...
QUOTE=mizhan;831196]Any V8 E39 will do just fine :biggrin:[/QUOTE]
Yup... agree with bro Mizhan
I would say if you include all cost, including depreciation and loan interest. E39 cost the same as a brand new 1.8l civic. Assuming 5 years ownership. But the driving experience is miles difference. The old one by far more fun. Personally, a make up E39 also looks better too.
In terms of driving experience, it's more fun than the 2.5l Mazda6.
Just my 2 cents
Yup do drop by 2moro st mmz from 4pm-6pm...
There is alot of E39er that you can make your choice huhuhu
aku bawak lori dan bas....ko adaaaaa...
yiukeng;831821 said:
i m from johor bahru. is jb member active in weekly tt?
Bro do check at member's meet up section...look for JB TT....
