QD250;558482 said:check:
top hose
bottom hose
and
rear hose , behind the engine under the cabin filter...
I cant check the rear hose cos cant see the other end at the firewall side. :sleep:
top hose
bottom hose
and
Alex5522;558516 said:Maybe u can jack up your car and run the engine and observe cum see will do.
perryyip73;558545 said:Jarance, this problem u must ask me wakkakaka, i experienced it. After jacked up my car few times only i found out the problem. Tonite i will let u knowDDD
boys toy auto;558886 said:hello bro what's up ,just read and want to inform to check the water jacket stopper by the side of the block , that is the side that people dont look . i've got that problem it was first the termostat housing but later it leak from the water jacket. ok best of luck.
terry8;541500 said:Hi gurus,
Really need your opinion. My water tank sensor lit up and I found my water tank empty so I filled the tank and also was careful to bleed the air out of the tank. After one day the tank was empty again. I took to a workshop which did a pressure test which showed that there is no leak because the pressure did not drop. The mechanic bleed the tank of air and filled it with water. In 24 hours, the tank is again low on water.
What can be happening ? Where is the water going to ?
Terry![]()
