jarance;541576 said:bro, that one not the Auto oil filter. It is the heat exchanger for the ATF fluid. I heard that the water can go the ATF line if the oil seal is damaged. There is a thermostat located at the heat exchanger as well. Change it as it tend to get blocked due to the residual of the coolant after it is expired.
jarance;541928 said:bro, what model is your car? It is E46 model?
solo;541938 said:Expansion tanks are always separate items. See here:-
Price of the expansion tank and labour to change it can be found in the Maintenance Thread.
Also, please find another salesman.
Salut
bmw7833;541960 said:Ohh sorry, mine is e39.
The salesperson are the staff in Auto Bavaria JB and Bavarian Auto PJ wor..
machaplai;541981 said:beware of this thing!just now taken
from engine side to behind
see!! leak..............
kena few time oledi...beware
my udm is e46 1.9cc m43 engine
IanDaddy;541942 said:Champion, I think you may have a leak at the thermostat housing (hairline sort of crack). Happened to mine, same sort of stain at the same place, over 6 months I have added 2 litres. Recently changed that.
solo;541998 said:Bro, where is the "engine side to behind." This is a little unclear. Can you give a more precise location? And what is the seal? This will help all of us with the same M43 engine locate it. Thanks.
Bro, kat mana ni "sebelah enjin belakang"? Tak jelas sangat. Boleh bagi tak lokasi yang tepat? Dan apakah "seal" tersebut? Ini akan membantu semua yang ada enjin M43 menetukannya. Terima Kasih.
Salut
StopMe_;544156 said:I am wondering... do I really need to release the air (coolant tube) every time I want to top-up the water in the expansion tank?
Anyone knows?
terry8;544174 said:Hi guys,
Thank you for your feedback.I'll talk to my mechanic today again. The problem has gotten worst. I have to fill up everyday now. Today it just "minum" 5 litres ! And today for once the temperature indicator showed hot.
The mechanic said it is not a head gasket problem because there's no oil mixture in the water.
At the rate this is going, i tend to believe there's a leak somewhere.
The mechanic will take the car today. Will keep you updated.
Terry
