EtEE
- Nov 4, 2010
- 46
fashraf;523576 said:Dear all sifus (including sifu Jarance), Need you guys input before I burn my pocket again..
My transmission error pops out again last night till now after almost 6 months. When this happens, the gear shifting become very rough and jerky. But the transmission still can engage all gears till 5th gear. But shifting down VERY jerky :afraid:
I notice that when I start the car this time, the engine oil check lights up in orange color (suppose this check the engine oil level only right?) then the transmission error pops out...
Went to mechanic, after check with the diagnostic device they notice the air mass flow have no reading. Went to change a new air mass flow (cost almost rm800) but the problem still there (air mass no reading + transmission error still there)
Is the engine oil sign (orange color) pops out for few seconds is giving some hint on the problem? Hope you guys can help... pleaseeee...:frown:
Hi Sifus,
I just faced this problem today, mine's an e46 325i. Experience rough and jerky when up & down shift. I can feel air rushing out from exhaust when gear change sound like "pop". Also felt treble and loud gear rotating noise on bottom centre of my car,believe came from the gb.
Then came on the emergency gear signal, where i believe it when into emergency gear. When I restart, every back to normal but you can still feel the heavy jerk when upshift, then the signal came back again.
To all sifus, pls give some advice.
