engine suddenly stop.
ichi82;771674 said:
did you get irritating noise and choking when put reverse gear..i diagnose using INPA it keep pointing to O2 sensor but i'm not sure if O2 sensor can cause engine to stop..will try to clean the MAF first before anything..
Totally no problem at all when I put reverse gear.I also not sure if o2 sensor problem can cause engine dead maybe sifu's around here know about that but if you was driving and then charging light came out then car jerk and shut down it self that one could be the MAF sensor (dirty) like happen to me before.So l ike you say better clean the MAF first before do anything.Gud luck to you,thanks.
pudin6037;771589 said:
Thanks bro,what I do to clean the MAF is open the MAF sensor and then shoot with the air pressure gun.same with the MAF housing,if MAF very dirty you can see alot of dust lah.Still can't belief this problem can make my car totally shut down.Thanks
Never use air pressure to clean the MAF. The air might damage the thin wire (for air flow sensing).
Use proper MAF cleaner like CRC Brand. See below
Thanks bro jarance for ur advice...do no about that before.
