David Yong;333890 said:Push them for an engine change and if possible... change to a 325 engine :wink:
That's exactly my plan!
Schwepps;334391 said:....Are they saying that their oil sensor is at fault and a dip-stick would be better? Geez, all these excuses are an insult to our intelligence!![]()
astroboy;334290 said:New car tend to consume oil because many hollow cavity in the engine block to coat and fill up. My Toyota faces this problem and I totally accept this explanation but it should end after the first oil change. Toyota first oil change is 1,000km.
No one know what kind of oil is the special grade oil because its specially formulated for BMW AG, filled in Germany before shipping the N52 out from its plant to Malaysia. The dealer cannot simply touch the oil without directives from BMW Malaysia or BMW AG.
Again, we are just speculating its caused by this special grade 1st fill oil..
Now oil level sensor pulak! All I can say is... stupid engine design.. no engine oil dipstick..![]()
dannis;334487 said:my dear friend, just trying to make myself feel better la... I'm aldy owned the car, seems like can only accept the fate.
Traveler;335539 said:I've been following this thread out of concern for my own E90 (2007 325 Sports). Here's my experience with the oil levels in my car:
1. First 15k km (including first service) - Oil level remained at max the entire time
2. Around 15-16k km - oil level dropped to about 3/4.
3. Currently 17.7k km - oil level dropped to about 1/2 while on driving on the highway (roadtrip).
wc9922;335593 said:u guys got an engine problem cause your block is magnesium alloy with alloy liners and the pistons are aluminium alloy. The rate of expansion for these materials are different and the diff gets greater as the temperature builds up. When this happens your piston rings aren't able to seal as tightly and you get blowby through the rings. There's where your oil has gone....into the combustion chamber and burned off or through the crankcase ventilation system into the intake manifold, which is more likely case.
Seach the internet, there's a warranty issue on the N series 6-cylinder magnesium based engine recalls performed. There is a check procedure they have to go through before they reach the stage where they will issue a new engine under goodwill warranty.
