kaiserrand;683399 said:Bro Alex,
Everything ok now already?
Alex5522;683405 said:Hi Bro i just went to BA Tmn Maluri yesterday and get my parts, so still waiting my mechanic after he finish cerebrate his Depavali on friday only manage to fix it.
Sure will update the out come to confirm whether is the RUBBER MOUNTING Rear was the culprit or not.
Btw i will change the 2 pcs of the RUBBER MOUNTING Front too. Cheers...
boys toy auto;683983 said:Hi bro ALEX5522 ,what's the result any good news. did the sound gone like the wind or came with wind .all the best .
JasonYew;684024 said:Hi Alex,
Mind to share to total damage?
Mine not yet produce any sound so far, but saw some small crack on rear rubber mounting.
kaiserrand;670819 said:Just to share, after replacing all 3 rear axle bushes and rear axle oil, the THUD sound is GONE! So if you're in a similar situation, jack up the car and take a look at the rear axle bushing. Most likely they're the culprits.
Alex5522;685022 said:Bro did your 3 rear axle bushes koyak affect your Rear axle support/wheel suspension Ball joint item no 2 and the prt no 33 32 6 775 551 as diagram below?
kaiserrand;685068 said:Not that I know of. I didn't check la but I read that if the rear trailing arm got problem (the item no 2 is rear trailing arm ball joint) then you will feel like you are unable to steer the car properly. My car has no such issue.
It has nothing to do with drive shaft. And the common failure point of the rear trailing arms are its bushings (item no 4 and no 3, but usually no 4 la).
IanDaddy;685044 said:I have the same sound occasionally but only when car is park on slight up-slope. Guess my bushings are also on the way out.
Alex5522;685325 said:Hi bro
You can do test with this way- Just engage your gear to R position with brake apply and don't release your brake and hear any Thud sound(knocking/kicking sound). You can do test this step with few time to confirm it.
Alex5522;685320 said:Bro i just change the ball joint(item no 2 for both side LR) today. I'm not really sure but i suspect it was affect by the 3 koyak bushing. The ball joint was koyak too and the symptom was my car got egit..egit sound coming from the back when come across the uneven road and crossing the bump. After check by my mechanic and it was cost by this ball joint. Now after changing the ball joint my car no more egit..egit sound any more when come across the uneven road and crossing the bump.
