Self-leveling headlights no-more
MSport
Guys, I just noticed that my headlights no longer do self-leveling (previously they do) when you turn on your headlights to "AUTO" when you start the car. Now, it's just stays there. Also, noticed the lights seem a bit low.Is there some mechanism or electronics gone wrong? I do not get any alarms on the OBC.Any advise?Thanks.
Good la! One less gremlins.. just adjust the height lights back via the headlight adjuster [if its possible], and let it stay there. Kao tim!
I seriously won't pay money fix that.
Can be the brittle plastic lifter like the E39 putus liao, which is a cheap fix, try get someone listen to check if the motor in the headlight still cranking. If total silent, motor also mati liao! or maybe just a fuse blown, since both side mati at the same time.. :p
