Guys..some info..
Octane quality is one of the many properties of fuel that is often associated with power and improved engine efficiency that is measured by the international standard for fuel, RON.
1. What is RON?
RON stands for Research Octane Number. It measures the combustion properties of the fuel.
2. What do the numbers 95 and 97 mean?
The numbers 95 and 97 represent the minimum RON value of a fuel that will prevent “engine knocking”.
3. What is “Engine knocking”?
Engine knocking happens when fuel combusts prematurely before ignition by the spark plug, which causes a “knocking” effect, resulting in loss of power. Using the appropriate minimum RON fuel that is recommended by your vehicle manufacturer will ensure that combustion happens at the right time to avoid “engine knocking”.
4. What is the minimum RON requirement for my car?
Your vehicle’s manual should specify what minimum RON value fuel to use. Sometimes, this information is printed on or around the refuelling cap. If unsure, please check with your vehicle manufacturer, authorised vehicle distributor or with an authorised mechanic
5. Can I use RON 95?
That depends on your engine. Your vehicle can use RON 95 if it is designed or set for RON 95 or lower. However, the best thing to do is to check with your vehicle manufacturer, authorised vehicle distributor or with an authorised mechanic.
6. What RON works best for my vehicle?
You should always use a fuel that meets or exceeds the minimum RON recommended by the vehicle manufacturer or authorised mechanic.
7. Can I mix RON 95 with RON 97?
As long as the fuel meets or exceeds the minimum RON required by the engine, mixing is fine and should not damage your engine. .
8. I am looking for power and performance, what is the RON value of Shell V-Power Racing?
Shell V-Power Racing has a minimum value of RON 97. However, octane quality is only ONE of the many qualities associated with power and engine efficiency.
Besides having the properties designated by its RON rating, Shell V-Power Racing is a high performance fuel with a specially engineered fuel formulation designed to help improve responsiveness, acceleration and power. It’s Friction Modification Technology (FMT), is the exact same technology used by Ferrari’s F1 team – a proud result of 60 years of Shell’s research and technical partnership with Ferrari.
Shell also ensures careful selection of the base fuel components used for Shell V-Power Racing to increase combustion efficiency, and incorporates other important fuel additives that clean and remove existing deposits from the engine.
9. How different is Shell’s Unleaded 95 from the Shell Super Unleaded 97?
Shell has been developing fuels for the last 100 years, perfecting formulas to help you get the most out of every drop. Our Shell Unleaded 95 fuel will also contain the Fuel Economy formula designed to give you extra kilometres at no additional cost.
10. What else is Shell doing to help drivers save fuel?
Shell is committed to ensuring that you get the most out of every drop. Besides bringing you innovative fuels that give your car the added distance, we are also educating drivers on good driving habits through Shell’s FuelSave tips that will help motorists save up to 10% in fuel consumption.
Visit our website at
http://everydrop.shell.com.my/ to learn more about Shell’s FuelSave tips.
