ALBundy
Founding Member
- Dec 4, 2004
- 11,610
- 38
astroboy;404822 said:Can anyone share how does a re-mapping work? Do they need to strap the car onto the operation theater to take all the readings from fuel pump pressure, injector efficiency, Co2 reading, AFM reading, spark plug firing intensity and duration, valve movement, combustion chamber ratio and what nots, to determine the new ECU map? or just one chip for all?
I know the F1 or even the E90 320Si and the //M engines are individually strapped into a lab to determined its most efficient ECU map to even the gear shift range.. are we taking about this?
None of what you listed will happened.
Most of the flash programs are generic. What normally happens is the local agent will read out your current software and other information from your ECU and then email the file to the proprietor overseas, say Superchip, Hiop and etc. The proprietor will then email back a new file (software) to the local agent whom will then flash it onto your ECU (this software will only work with your ECU and hence prevent the local agent from piratising it
Of course, you could tell them your beloved ride has CAI intake, free flow exhaust, high flow injectors and what not. But how would they know how much to customise? Even if you give them your AFR map, that is only at WOT. As we all know, the crucial part is the part-throttle map, which given all the modifications, it would be impossible to get it 100% accurate unless a dyno tuned couple with on road fine tuning, and to do that properly given the number of matrix points will take a few days. In fact, if you noticed when a local tuner does a tuning via piggy-back ECUs, a lot of interpolation is done, otherwise there is no way he could do it in half or even a day.
Cheers
