kuntakinte;647804 said:I think it's a typo on doc's part. Should b 225 and not 255 on the fronts. No way u can get 255 for $540 anyway. Mixing different tyre types and even brands is ok as long as they are on the same axle.
Btw doc, I had my left front and rear rims hot pressed too when I changed one of my punctured rft a couple of months ago. Charged $95 per rim. And like you, they 'discovered' it after a courtesy balancing on the other wheels. Hmmm! Wonder of it's some ploy but let's give them the benefit of doubt first. On the camber adj, can't comment on it as I didnt do alignment but I do read on motoring mags that in the absence of a camber adj kit/screw on the wheels, we should avoid high pressure camber adj tools as we may risk damaging the components. Anyone care to verify?
docrayboy;647742 said:the rears wear down much faster than the front because of our RWD.
jim2106;628565 said:Guys i was quoted around rm 1100 for potenza rft 255/40/17
Yr 08
Source : the famous kedai papan kelang ( if not mistaken jln meru)
RAR;637389 said:anybody interested to buy spare tyres? I have 3 original BMW 17inch rim, 188 model with RFT. Suitable for e90. rm650 each. PM me if you interested. tq
nik1979;649300 said:reading this, noted that it is better to use non RFT tyres. Unless you have very deep pocket to spend for tyre replacement.
Looks like not all punctured RFT tyres are repairable. Anyway how do they patch RFt tyres? is like normal RM5 patch? If your car punctured and immediately decide to stop at road side, better just call tow truck instead of drive further which might cause RFT tyre further damage?
DKNY;651011 said:Had to patch up the tire twice in 2 days as there was two leak. RM5 patch did the job!! ANyway called Bridgerstone and they confirm you cant dissemble the tyre from the rim as it'll break the tyre wall due to its rigidity!!
Pointer make sure the dudes never use the air gun to open your nuts as they grinded away the BMW lock nut!!
ouch I wouldn;t have done that as the electrical surge from the welding rod can fry your ecu and most part of the car!!ahmz;651030 said:Had that happen to my ex-pug 307SW. Had to resort to welding to loosen and remove the lock nut.
namidub;652945 said:Lucky you could do the RM5 patch.read my story.its a big hole on the tyre and my pocket!
http://www.bmwclubmalaysia.com/foru...ory.-Special-thanks-to-Choq-and-dzuljazz2001-!
noobie;658182 said:conti csc3 SSR RFT 245/40/18 - SGD420 per pc. with nitrogen + balancing. I just changed my last week. 4pcs. SUPER VALUE for $$$. manufacture date 1611(week 16 yr 2011) Made in Germany.
