My Hall Of Fame >> My Ultimate Driving Machine(s)
anakin;717093 said:
VJ...short shifter arrived already ar? Got extra for me?:wink:
this one I got from the States...see my post above, you can take the part# and order from BA or IP....Albert busy sangat :)
you not installed it yet ? sure must be excited to put it in... can try imaging it...hehee
collected from POS Laju and immediately installed it... :p thought you will be at the TT for some tips but heard you could not make it...btw, the short shift is SWEET ...
yehh tested it and the throw of shift is just a mere fraction ...just like dropping the auto lever from P to D ...
this car flies now ....
^ I wish it flies...if mine flies...yours?? super flies :)
my clutch held at customs...need to sort out...damn !
damm that's gonna be tough bro ... ?? try to appoint those pos laju ppl to clear it for you ...
yup, pulled my back last weekend, wasted a 2 days in bed...
pardypeople;717429 said:
pulled ur back on the BED too ? :p
No, in the se7en la, slept with the seat reclined, then woke up, yikes :eek:
initialM;717452 said:
wah 2 days in bed. sure air kering abis
No, la.. i came sayur la... try moving with this pain...
pardy ..the new avatar looks good ..but how does it look in real ....some pictures plss...
sadly it may not come true...let see how it goes..nvm, to compensate, tomorrow I post some goodies for your viewing pleasure :)
P/S: I might just take the risk to try Yakuza style ...have some plans in mind..hehehe
Some decent looking shots on standard wheels over the weekend...
Centerforce dual friction clutch kit finally arrived...2hrs for Customs clearence :stupid:
Rated for 450 ft lbs
. SPEC Stage 2 rated 310 ft lbs.
The Centerforce Dual-Friction clutch set is a performance matched pressure plate & disc combination. Centerforce Dual-Friction pressure plates feature their patented centrifugal weight system (where applicable) and specialized machining processes to provide a performance clutch that offers exceptional street characteristics, while offering outstanding holding-capacity and durability. Furthermore, the Centerforce Dual-Friction disc has a full facing on the pressure plate side for drivability and longevity, while a carbon composite puck style (segmented) facing is used on the flywheel side for a positive engagement and increased holding-capacity. Dual Friction is engineered for those who are looking for the ultimate in street/strip holding power and performance without sacrificing pedal effort and driver control. While the Dual Friction has been engineered primarily as a street clutch it can be used in mild competition applications.
