The car is an Auto, but it has a selector which allows you to switch from E-S-(3-2-1) and it works!!!
Economy (uses gear 1-4)
Sport (uses gear 1-3 only)
3-2-1 is manual select (1- first gear, 2-second gear, 3- third gear, D- forth gear)
I find that with the auto box and the 325i engine conbined with the lightweigt of the E30, the drive can be quite spirited too. The shifting is quite smooth, I can barely feel the downshift when I floor the pedal. Cruising at 160 is very silent and controlled, but I fell the suspension is kinda springy. I hope a good new spring will solve that problem.
On the suspension side, here is a list of all the rubber parts I've changed so far...I opt not to go for PU bushes because I want to maintain the stock ride quality.
Subframe bushes
Trailing arm bushes
Transmission bush
Engine mounting
Control arm bushes
Antiroll bar bushes
Suspension mountings
Flex disk
Long shaft bush
All coolant hoses are new
Thats all I can think of, hope the sifus can tell what other part I missed. Tks for all the comments.
