M.Directspares
Club Vendor
- Jan 30, 2005
- 1,206
- 38
nice, u need to do her justice, better photos and location pls. + photos of your 5er
supafly;482527 said:nice, u need to do her justice, better photos and location pls. + photos of your 5er
Zul;482582 said:I'll try over the weekend...
Regards.
-Zul-
gremlins;518766 said:...Salam bro zul,...ini aku lah Azmi....wahhh...bro...kau punya M3 tambah meng"ghairah"kan bro.....aku tak dapek lah.....525 pun dah cukup lah.......see you bro....all the best...( bro, 530 tak nak jual ke...heheheh..)
Zul;532345 said:Hi ice pop,
The car ori rims was 19" before I change to HRE C20-3 piece rims. It was an improvement in term of handling from the ori rims because the HRE rims is among the lightest rim around. Then after few months I change to the Hamann Edition Race 20" 3-piece rims. The rims is havier than the C20 and ori 19". It affects the starting/pick-up of the car but I can still spin the rear wheel up to 2nd gear. It is 'harder' but i can live with it, not bad for a performance car. BTW I have the E60 530I if I want comfort with some performance. Don't think there is much improvement in handling. I think it is more of aesthetic than performance gain with the 20" but I don't think U will lose any performance significantly.
Sorry, the ori 19" is well kept in a box, not planning to sell it. the HRE 19" now on my E60 with a spacer to fit on the E60.
IMO if you want to upgrade/change always go for good quality than taiwan made because I'm sure the taiwan made is inferior in quality and heavier. The max U should go for E92 M3 is 19" if U still want to maintain the comfort and performance, 20" is mainly aesthetic/cosmetic. The tyre of the 20" won't rub the fender but it rub the plastic cover of the fender, with my set-up I can hear the sound of the tyre rubbing the plastic fender cover on max turn of the wheel.
Zul;532635 said:I'm not sure whether the E92 335i and E92 M3 share the same wheel spec. Anyway the spec of E92 M3 Rim:
1. BMW Style 220:
8.5x19", ET 29 (FA), 11 kg, 245/35, 9.5x19", ET23 (RA), 12 kg, 265/35
2. HRE C20:
8.5x19", ET 28 (FA), 8.5 kg, 10.5x19" ET 31 (RA), 9 kg.
3. Hamann Edition Race:
8.5x20", ET 26 (FA), 14 kg, 245/30, 10.5x20", ET 26 (RA), 15 kg, 295/25 (+ 3mm spacer)
