Strider;500106 said:anybody selling m40 manual gear box?
Aero;500330 said:is sound like those from a lorry with Grrrr Grrr sound within the rae of 2-2.5k, during accelrating and also decelarating. magnetic bolt dont have, is it available in the market, by the way how can we take care of the gear box, if it is the bearing problem, any change of repair or it not worth the repair.
Thanks
datsunnismo;500367 said:bro.... still havent get ah?.. anyway good luck hunting for good one.
berserkdroid;500474 said:The Getrag 240 can be rebuilt, just get the bearings (especially the big one at the spindle), but when reassembling you got to use a few cable ties to hold the gears together. As the gear assembly goes into the box, cut the ties one by one.
For cheaper cost, get SKF bearings.
jumpman;500907 said:Wad about when ur gears grind when you engage in downshift? or when u upshift above a certain high rpm..synchromesh issue ?
fabianyee;500468 said:I'm running a E36 318i/325i Getrag gearbox after my Getrag 240 started whining due to worn bearing..
Aero;501376 said:Hey that a good suggestion,where can i get it done and how much is the bearing, can you recomend, as when when i shut down the car ou can hear that there is knocking sound coming from the center or almost to the back of the gear box near where the long shaft connect. by the way which bearing are you refering as near the spindle, do you have diagram.
Have you done the rebuilt before.please pm me the cost and location.
Thanks
berserkdroid;501384 said:Does the knocking sound go away when you press the clutch?
My friend and I did the gearbox rebuild ourselves, just for the hell of it. Actually just replacing the main bearings should be good enough, but we got itchy and changed ALL seals and bearings. That and some redline oil makes the gearbox pretty nice.
Some of the other guys on this forum have had their boxes fixed at shops, do a search and you'll come across some interesting threads.
Cheers!
berserkdroid;501393 said:Yup its the clutch release bearing, the usual culprit for the symptoms you've described. Also, change part # 12 as illustrated here:
http://www.realoem.com/bmw/showparts.do?model=AJ52&mospid=47273&btnr=23_0516&hg=23&fg=15
These problems usually happen when the gearbox is run with insufficient oil, or when a mechanic reinstalls the gearbox by whacking it with a hammer to make it fit to the engine.
With regards to the seals, are you leaking any gearbox oil?
