Help on getting an E90
You may be looking at the semi-synths or even minerals, viewfinder. Castrol is a brand. Mobil1 is a range just as Shell Helix and Petronas Syntiums are ranges and there are many types of oils within a range. You need to specify Helix Ultra AB and Syntium 3000 LL for the fully-synths.
Basically, Castrol spoiled it for the consumer by it's marketing actions in 1999 and it became difficult for the consumer not to get tricked the world over, except in Germany and Japan. Here's the story from the Amsoil website:
What is "Synthetic" motor oil?
As with any new technology, there are a number of myths and advertising claims that need to be explored.
In 1998, the Society of Automotive Engineers (SAE), a US based organization, deleted all references for the term "Synthetic," to avoid any future lawsuits. The SAE is a non-profit organization of Engineers, which had no desire or financial backing to involve itself in lawsuits with Major Oil and Chemical companies, so the simple "deletion" of all references to "Synthetic" was made.
The SAE "Synthetic" rules previously stated:
"Synthetic base stocks must be Poly-alpha-Olefin [API rated= Group 4]."
Castrol Syntec took advantage of the rule deletion and released a "Synthetic Motor oil," using highly processed mineral oil [API Group 3] base stocks.
Exxon Mobil sued Castrol for false marketing in 1999, and unfortunately for the consumer, the judge declared that 'Synthetic' is a marketing term NOT based on its components. Group III base stocks are now considered synthetic motor oil in North America.
The entire Synthetic market switched from using Poly-alpha-Olefin's [Group 4], to the much cheaper Processed-Mineral Oil [Group 3] alternative, while retaining the premium PAO Synthetic price. AMSOIL is one of the few to continue using 100% PAO synthetic base stocks made with expensive pure chemicals.
Schwepps,
From the label, is there a way to tell whether it's G4 or 3? This is an old SL grade Mobil1 SuperSyn 10W-30 left over in my store room.
(sorry for off topic a bit)
I think it's G-4, but I'm not familiar with Mobil products. But if it's old oil, it's probably best not to use it. Lube oils have a shelf life too.
One way to check is look for sediment at the bottom, if you see them, then the additive has already separated from the oil thus the additive is no longer "functional".
I am thinking of using it in the lawnmower's nxt oil change if there's no sediment :rolleyes:
Cool! great way of helping the environment then just discard the oil.. :top:
Finally got my ride after a whole week of owning the car. So Schwepps was asking about the RTF driving experience, so this is what I have to say.
Driving on RTF is quite an experience. I would think the ride is a little noisier ( comparing with my Dad's E240). I don't think the Merc's insulation is any better, I think it is the tyre, cause on stationary and Idle, my 325 seems to be more quiet then the E240, but when travelling at say 120km/h, his car seems to be quieter. The ride i s a little bumpy, but don't have a comparison here, the tyres are really hard.. Maybe the tyre is a little pump a little on the high side, it was pump by Ingress Auto SA. Havent' driven the car whne it rains, so no comments on performance on wet road.
RTFs? You mean RFTs :) We're all using RFTs here if we buy new E90s. It's just that you mentioned that your unit will be on Pirelli RFTs and nobody here that I know of has used Pirelli RFTs. Are they Pirellis, and if so, which model? I would be interested in the ride, handling and wear rate. Ride and handling of Pirellis are bound to be superior, but they have a rep for poor wear rate.
sillycarx, you may want to get a N2 fill with proper pressure gauge measurement first thing in the morning and see if it makes a difference. If not, then it's the way e90 suspension is setup.
Most places use the al-cheapo spring-tension type that's unlikely to be calibrated. I found a place that is using a pressure gauge, but need to pay a few ringgit to fill.
