GB for K + D Can USB Cable (INPA compatible)
Status
Not open for further replies.
jarance
Founding Member
Location
KLlang
Here is another Group Buy for:- A. K + D Can USB Cable. (RM240)The cable come with DVD Rom (2.6GB) which have DIS-55 Software running with VWare and INPA-EDIABAS and USB Driver.It also have a video tutorial on the setup of the program.Offer price : RM240 per piece.please add RM10 for poslaju to anywhere in Malaysia.
________________________________________________________________________________________B. BMW Scanner 1.4.0. (RM170)C. 20pins to16pins adaptor (RM10)A. K+DCan USB Cable (RM240)1. 2. B. BMW Scanner 1.4.0 (RM170)1. 2.
Thanks Jarance for organizing this one. Cheers!
1.
2.
1. Aidil + RM10 for poslaju
2.
C. 20pins to 16pins adaptor
1.
2.
aidil, may I ask why you are going for the scanner 1.4.0.
you have the other type of cable which is more "advance" as compare to scanner 1.4.0.
scanner 1.4 is more for the novice or an introduction to bmw diagnostic. you are in the super advance class.
Jarance, the scanner 1.4.0 is the one that I don't have. Unlike the KKL interface, I can't make this one since there is a microcontroller inside. I'm also missing out on discussion on the scanner since I don't have one..
knowing, you most probably will hack the scanner.
here is the internal view.
1. EL118
2.
2. EL118
1. EL118
2.
Hi Jarance, D-can ok for E66?
1. EL118
2.
2. EL118
3. m3addict
4.
1. EL118
2.
Good on Jarance on the GB. I have already got them all plus some others.
aiyoo, I know you want to make me jeles.. ha..ha.. OK show me your weapon of mass destruction.
Here is mine..
current set
Left is EDIABAS/INPA interface, right is ELM327, offset is the USB-to-serial
1. B33MER - 1 qty
2.
2.
1.
2.
Here is the internal part of the K+DCan USB cable. SMD Soldering work is first class if I may say so.
1. EL118
2. B33MER - 1 qty
3.
2. EL118
3. m3addict
4.
1. EL118
2.
Here is mine..
No lah, I don't have the 3-In-1. I have a BT ELM327 and a Ediabas OBD (serial). I am thinking of DIY a cable like aidilj, I notice that the quality of the connector on the K+DCAN cable I bought is not that good (the pins are uneven)
Honestly, I admire your passion.
Nicely done, two Atmel chips, one is a microcontroller
IanDaddy, sometimes it is by design to be uneven. Pins 4 and 5 I think are the ground and they potrude more to make sure when you plug it in, ground will be connected first.
1. EL118
2. B33MER - 1 qty
3.
2. EL118
3. m3addict
4. Mtigo
5.
1. EL118
2. Mtigo
3.
jarance;639523 said:
no sure about E66 but on the BMW INPA Menu, E65 model is listed.
E65 ok than E66 no problem. thank you very much!
Status
