bro dark1234, if the water vapour goes away, fine - because if you check carefully, there are drain holes in the bottom plate of the headlamp units - but, I wouldn't accept water droplets IN the headlamp units themselves, because this might mean that there's a LOT more water seepage than what is expected. Good luck!
Bro, where did you get the forgestars? I wanted the black carbon center hub caps. Anyone can help ?? I called StillArt but they dont carry extras. If not, i';ll have to order from the states. whichmeans waiting haha...
manjohari;690731 said:
some update, with Forgestar F14 - 19" - Glossy Gun-metal
picture below taken using mobile phone
tomorrow will wash the car and take using dlsr
hopefully not raining...
Nice rims...I just got mine in matte black, same tires Will be getting slime kit and perhaps a spare filler tire for bad punctures to stick in the boot. Currently looking at the storage conditions, will probably build a compartment for it and blend the carpet in.
A slime kit is a tire repair kit - the basic set comes with a can of sealant (the slime) and a simple compressor to pump up the punctured RFT. The more expensive set comes with a more powerful compressor, 'sticky gum' sealants to repair side wall damage, as well as the slime can. The cost is about S$85-180, but I think is way cheaper to get it from Malaysia.
I swapped my standard 18" RFT to 21" pneumatic rubbers when I upgraded my rims on my F02 - no issues with tyre sensors whatsoever
