Here the latest update on the engine.
Open the engine and found the following problem:-
1. gasket blown
2. top head cylinder slight warped
3. cam rod slightly worned out
4. tapper worned out
5. One piston ring loose. can move the piston. (need to change the ring)
6. oil seal for flywheel leaking
7. front oil seal also leaking.
So many things worn out.. I am going to retire the engine and put it to a greener pasture.
Went around asking for an engine M40 1.8l empty engine. Got it for RM1500 after nego. Thanks to those who have offered and help in purchasing the engine. (come with AP paper)
Now the engine is at the workshop. can't wait to see the car with a new heart..
OK what are the do and don't when upgrading the engine from 1.6l to 1.8l. Heard so many advise. pro and con. here are the list.
1. throttle body (must used 1.8l)
2. ECU (must use 1.8)
3. brakes (must upgrade)
4. fuel injectors (better to upgrade or keep original)
5. change the timing belt to be on the safe side (don't know the milage )
6. change the oil seal (wear and tear or due to aging)
7. exhaust manifold (keep original or upgrade)
Will keep you all posted with any new update. please advise as I need all the help that I can get to get the car running in tip top condition.
k:
k:
1. gasket blown
