astroboy;507643 said:You want to be noticed la.. that's why the motorbikes too switch on their headlights.. for the humble me, its for safety reason ma..
I buy BMW not for "Look at me" reason, that's why I picked a black one..![]()
Daytona;511441 said:It's amusing to read why people flash and tell you your driving lights are on! It's not as if you are parked and forgot to turn off your lights.
Traveler;511463 said:... Don't these people look at their dash gauges and realise that their lights are OFF?
Schwepps;507700 said:DRLs started in the Scandinavian countries where the winter months are long, and the ambient light is low even in the daytime. It makes sense in those Arctic Circle countries, and Russia and Canada. It hardly makes sense in latitudes where the sun is virtually overhead.
If it's really safety that causes you to switch on your DRLs, then good for you. But be honest with yourself WHY you switch them on. Also think what other road users here think of you:
1. Neutral - don't care
2. His lights got problem
3. He doesn't realise he left his lights on
4. What a dork! (me)
If your real reason for having them on isn't safety, it kinda defeats the purpose doesn't it? Sorry if I've offended anyone.
Mun;572679 said:Just discovered that we can adjust the angle of the headlights. The initial (factory) angle is on the low side and didn't get wide distribution. ( My wife's Jazz seems to give wider and longer distribution!) This is a problem when going fast on roads where we don't really know the surface. and recently the left side seemed to spot lower where I can see a long diagonal band close to the front panning to the right.
So browsed E90post forum and discovered the unit can be adjusted.
The tip was about 2 turns CCW for passenger side and 1 turn CCW on driver side so as not to blind the incoming traffic.
So much brighter now, and in fact you can adjust left and right angle too.
tip - if you are lighting road signs brightly, then it is too high. Also can test by sitting in an opposite car.
Btw, I don't switch on DRL but turn the switch to the left (A). make more sense to lit automatically as going into penchala link tunnel, covered carparks, heavy rain and approaching dark.
sharp;572962 said:spaceman, then its time for u to fit HIDs in ur corona rings
sharp;573208 said:spaceman, current HID for corona rings are plug n play, no modifications needed
