E60 parts & maintenance
pumpkin76 said:
Hi bro moots...
Yeah.... I thought I read somewhere in your post in Dec 2014 that you replaced your battery for RM550? Big difference with RM720 even including GST if you ask me...
You from BBN?
Hi All,
I was quoted Bosch S5 DIN100 for around RM 480.00. Any comments for those who used Bosch battery before?
Hamansan
Good price for Bosch DIN 100 and should be ok to use.
hamansan said:
Hi All,
Hamansan
Hi all
Done my parts changing and repaired on petrol leakage:
Fuel Pump O-Ring - RM200. Per piece is RM100 x 2
Front Absorber RM540 x 2 = RM1,080
Front mounting RM310/pair
Absorber shaft bush RM96/pair
Absorber cover RM80/pair
Labour RM80
Alignment FOC
Total price RM1,846
Twll said:
Hi all
Labour RM80
Alignment FOC
Total price RM1,846
bro, the front absorber, original? msports?
Its Germany brand not the original absorbers and not msport i guess. Forgot to ask the brand name but so far satisfied with the absorbers
Hi all! Now is my turn contributing to the statistics and database...
Did my first service last Saturday @ mileage 95K kms, Car is E60 LCI 523i Manual:
Parts:
Oil filter RM42.00
Air filter RM98.00
Gear lever oil seal RM68.00
Gearbox Output oil seal RM84.00
Gearbox mounting (2x) RM150.00
Lubricant:
Ravenol Fully 10W/60 (5L) RM285.00
Ravenol Fully 10W/60 (2x1L) RM118.00
Brake fluid RM40.00
MT Gear oil (1.5L) RM247.50
Labour:
Inspection Service RM80.00
To change gear lever oil seal & output oil seal RM150.00
To flush & bleed brake & clutch fluid RM50.00
TOTAL RM1,412.50 + RM84.75 GST = RM1,497.25
Optimum Kayu Ara...
I was surprised the M/T gear oil (RM165/L) is more expansive than the fully synthetic engine oil (RM59/L).....
Hi all,i just have my E60 525, year 04, can i know my petrol should use ron97 or ron95? Coz when i pump ron95, my car seem like delayed a bit when i press the pedal.
RON 95 will do. check your intake manifold system.
Yes ron95 is okay... lowest at my fuel cap printed ron91... my car engine type n52
Gearbox/engine lower cover RM 700 (blardy expensive) but no choice as I have repaired this 3 times already and it still sags as the attachment points koyak ady...and there's only so much my back can take whilst crawling under the car.
pic of old cover
Thought there is a OEM version of the said cover? Something from Taiwan which costs half the price.
Thanks Herbet, i've checked my fuel cap there is same with yours,but after i pump Petron Ron95, when i stepped the pedal, the car not going smooth. So i used back ron97 and this problem solved, i just wanna asked whether the ron95 will affect my engine.
Bro Herbert, i've tried 1 fulltank of Petronas Ron95, the problems not occur, will see how after few more tanks. Thanks for the info.
Did a major maintenance at M Speed USJ
Hi Calvin,
Your symptom same as mine, when put back RON97, much more responsive right.... So, i believe is petrol issue, but when i put Shell RON97 less power, so I insist on petronas RON97... :67:
