E60 parts & maintenance
moots said:
:64: huiyo...so expensive the windshield.
He He....go get a new SA.Change at 99950km kenot but change at 110k kms ok.He is technically incompetent.
You car has done approx 60k miles...so that's about an ok mileage to have the atf fluid replaced.If you have done 160k miles then that's another story that you can google where a fluid change at this mileage may damage the gearbox.
Thanks bro..will definitely get another SA
amos said:
Just replaced front brake pad @ Euro Tech Motoraports.
Textar front brake pad & sensor = RM198 from BA
Labour cost = RM60
Total cost RM258
hey bro, u encountered any noise (whistling) after the change?
KK Gohnsen said:
Just send my E60 for windscreen change cos hit by stone at BMW IA,Puchong (coz they able to arrange for insurance claim-avoid the hassle of documentation):-
a) Front WS - 4,021.23
B) Sensor - 97.67
c) Rub Buffer - 42.40
d) Cover - 73.81
e) Sika Flex - 32.50
f) Sika Aktivator - 43.00
g)Sika Primer - 206 G+P- 78.00
h)Labour cost - 600
i) 3M Tint Cristaline 40 - 800
TOTAL : RM 5,824.61
At the same time also ask to service my car which had done 99,950km (first time to IA, previously I normally send to AB).
a) Filt Element - FOC
B) Syntium 3000 LL01 5W-30 (6.5litre) - RM600
c) Service - Std Scope - FOC
d) Engine oil service - FOC
TOTAL : RM 600
I ask to change my ATF as well since I never change it but was advise that no need to change it now as I miss the scheduled change at 70k km. If I change now may have problem with the car. The service advisor ask me to change at around 110k km. Why is it like that?? It is true?? I don't want my gear to be condemned after that!! Anybody can advise?? The service advisor seem not very technical sound :68: :56: :56: :56: !!!!
bro, ur WS is dot3 or 4?
rear window rubber trim rm123/- at bav auto USJ.comes in 1 piece which covers lh,top and rh
old
new
what needs doing is to ensure the glass goes in the trim's channel
tools used
done in 1.5 hrs
moots said:
Sorry la bro but i donno the cost.maybe it's posted in this thread somewhere before.And what's a radiator cover? :stupido3:
No idea what is radiator cover,
old
new
tools used
done in 1.5 hrs
My car is having the same problem with you. I was told need to take out the entire rear windscreen!!!. Almost naik lori liao.
Send mine to BMW IA Puchong to change the rear rubber moulding as well.. Total for RM 256.32 for 4 sides...so far so good
old
new
tools used
done in 1.5 hrs
where was it done pls address n number
Harbajan,
It was done by moots himself (DIY). Perhaps moots can have it done for you for a token fees.
Just update my maintenance here recently,
Auto Filter, auto oil pan, auto oil Rm900
Change Oil sum gasket because leakage Rm200
Removing and intstalling oil sum gasket Rm200
Fly wheel oil seal Rm300
Removing and installing gear box to change fly wheel oil seal Rm300
Power steering pressure hose (used) Rm380
Power steering oil Rm45
Total bills at Rm2325.00
Continue for my maintenance update here
Change tyres 2 units 245/40/18 (nexen 8000) RM550/piece RM1,100
Change 2 lower arm (big) RM480 x 2 = RM960.00
Rim that got bended repaired back RM110 x 3 pieces = RM330
Alignment RM50.00
Total RM2,440.00
Change Engine oil and oil filter RM304.00
Brake pad front RM320.00
Brake sensor RM60.00
Labour RM15.00
Total RM699.00
Hope it drives well now
bro how's the Nexens....I will be due for a change very soon....
i have tried nexen before, car become shaky after 10k mileage.. alignment & balancing no issue. recently changed to michellin PS3 RM850/pc - the feeling is aaaaawwwwweeesssooommmeeeee - handling, grip, performance and more important thing no more shaky issue.. i think it is worth to top up rm300 to get the full satisfaction. just sharing my experience here
Previously my ride was on Nexen 8000 and no issues with alignment & balancing. However the only set back was speed above 140 km, car tend to be unstable and had this "floating" feel. Having said that, I personally think it should be worth your money for those non-rempit kakis. Had the Nexen 8000 replaced with Michelin PSS 2 and what a world of difference.
correct, my case is when the speed is above 120km.. like your word "world of difference" :rock:
Hi bro,
So far i have driven it for 2 months after changed and it was okay for me as i dont speed all the time. Alignment and balancing no issues so far. Of course if your budget permits and would like to go for faster speed i suggest bro can go for Herbert and Jason recommendation. Premium tyres will get you to better enjoyment of riding it. Hehe, so far i ride my E60 maxed it 120km/h. In kl hardly can ride fast.
Btw any bro can enlighten me abit. My mechanic said thermostat and water pump need to change and it cost roughly about RM2k plus for all. I tried to search previous cost in changing water pump and thermostat but i guess different model different price for it. Mine is E60 520i. Can i ask any feedback on the price of the parts?
