E60 parts & maintenance
harry_7;787887 said:
Mine also, my mech charge me 8 litles...
Mech will charge 8 ltr since they need to open 2 of 4 ltr bottle mah.
Unless they charge you by ltr. But engine only need 6.5 litre or less and you keep the rest for top up or add for next oil change.
I bought my oil in carton box last time as I change oil every 5k km.
They charge me 8 littles but didn't give me the remaining wo... Feel like being cheated....
Buy from First Division AutoParts Sdn Bhd Segambut :-
1. F/B Tensioner - RM230 (brand name Inna)
2. F/B Bearing - RM125.00 (brand Inna)
3. Fan Belt for E60 N52 - RM75 (brand Continental)
4. Aluminium Screw - RM18 (from Bavarian Auto)
My friend's 2007 523i is so problematic, since last 3 months, the following item has been changed:
Radiator fan: RM2500
Valvetronic Motor: RM1500
Fuelpump: RM800 something
Fuel filter housing:forgot
Starter:forgot
Radiator hose: RM125
Starter:forgot
I don't think your friend's car is so problematic. It is part and parcel of owning a 5 years old car where parts/components would gradually be worn out. Expect more worn out parts to be replaced over the next 6 months.
Hi Guys,
Did some maintenance on my E60 525 M-Sport year 2006 last week at Bimmer Auto, Kuantan.
The car showing symthom like misfire. The engine running just like Impreza (Boxer Engine).
Towed the car to the shop and diagnose showed that Ignition Coil for piston No-2 was kaput.
Here is the list of my spending...
1) Ignition Coil : RM 200
2) Oil Filter: RM 60
3) Flushing-oil (Shell): RM 105
4) Engine-oil ( Liqui-Moly Top Tech): RM 420
5) Engine-oil 1-Liter for top-up: RM 60
6) Labour charge: RM 130
Total spending: RM 975
Current Mileage: 49,216 km
Next service: 59,216 km
zack, are you sure your car's mileage is correct? if it does looks like your car is stationary most of the time
affan66;795250 said:
in other words, he is a seamen... hhheeheh
Affan... Just helping to increase our country's income... Hahaha... :top:
Mash... Half-life at offshore but spending my whole year income for my Baby 'B'... :24:
Beemerback, the mileage clocked about 22,300 km when i owns the car from recond car dealer in Ampang area. So, i just take that as my reference. Since then, i'm servicing the car ( replace engine oil and medical check-up ) on every 10,000 km. Cannot considered as my daily 'work-horse' since i am only spending 2 weeks in a month with my car. :top:
My rear brake pad was almost gone, so went into Optimum to get a new set.
Also took this opportunity to install new brake hoses which I had purchased earlier.
Here are the charges.
Rear Brake Pad (Original) 385
Rear Brake Sensor 60
Brake Fluid 40
Service Charges
Renew rear brake pad 30
Change brake hose & Bleed
brake fluid 80
Total amount before service tax 595
Here is what I have done recently for my car:
Front brake discs (2 pieces; original BMW) *mine is 530i so the disc size is larger, 348mm x 30mm* = RM720 each
Boge/Sachs M-Sport absorbers with mounting, protective cover = RM3,100 for all
Labour = RM300
Recently did some routine maintenance:
- Front absorber mounting = RM70x2
- Front absorber bump-stop/cover = RM21x2 + RM15x2
- Rear absorber mounting = RM70x2
- Rear absorber bump-stop/cover = RM40x2
- Bosch Aerotwin wiper = RM100
At which workshop bro? Can let us know?
Fixed overheating problem while on the way back to Ipoh
Problem: Thermostat stuck partially open ( no overheating problem when driving at low speed)
- Replace thermostat RM250
- labour RM60
Water pump could be next on my list of things to change.
24 January 2013
Mileage : 130,000++ KM
Ignition Coil (Bosch) RM120 x 6 = RM720 (Only 2 fault, but i decide to change all )
Spark Plug (Bosch) RM65 x 6 = RM390 (Find out my car still using original BMW spark plug, time to change)
Front Parking Light RM100 x 2 = RM200
Total = RM1,310 .. After discount RM1,200
Autobahn Sunway ...
azam9636;800995 said:
24 January 2013
Bro, thanks for sharing. The Bosch plugs appeared to be expensive.
