E46 Alternator/Voltage Regulator Failure Symptoms
Bro wingzee did your EML light lights up ? I remember last time my EML lights up due to ICV stuck.
Nope bro Alex. It didn't. And no error code was detected too during diagnosis, which is why am abit lost.
B33mEr;797002 said:
Could it be your idle control valve that needs cleaning maybe?
Also Bavarian Auto is selling Bosch alternator for RM850 new
RM850 is for 2 pins. 3 pins is RM1400.
wingzee;797043 said:
Yeap it died the moment i turned on the air conditioning. If that's the case then likely it's the ICV then. Thanks fot the detailed explanation bro. Shall clean it this weekend & see how it goes.
What will you be using to clean it? Don't use WD40. It does not require lubrication either so don't spray anything else in there. Dirt will just stick to it more easily.
No problem! If you need anything else just ask
I shall refer to my mech. So a pressure gun should do the job?
wingzee;797150 said:
Mine M54B25 should be 2 pins? I hope?
Need to check VIN or unplug the alternater socket then only know. My friend also using M54B25 local spec is 3 pins.
Checked and RealOEM shown the below:
No. Description Supplement Qty From Up To Part Number Price
01 AT-COMPACT ALTERNATOR 90A 1 12317501687 $477.22
01 AT-COMPACT ALTERNATOR 120A 1 12317501599 $561.43
Might be the 3pins since it costs $477.22 at minimum
Don't think it the ICV. ICV problem does not stall the engine.
Don't think it the alternator. Voltage is ok.
Check the air filters first.
Check for vacuum leak.
Thanks Jarence. Planning to check on that as well & clean the ICV to solve the idling problem.
Car seems to be running fine and cranked up well in 1 go. Engine never stalled again since that first incident. However, lately whenever the car is revved softly with interior lights on, the lights would dim slightly and back to the normal brightness. The dim is accompanied by a slight dip in RPM, even when the accelerator is pressed. Is this a sign of failing alternator/unstable current?
Have checked with BA and my alternator costs RM745. Suan Huat at Tmn Paramount quoted RM850.
Was told by Albert of WP Auto that our E46 uses 2 brands of alternator: Valeo and Bosch.
Alex5522 said:
Changed mine almost 2 yrs back and use my original alternator till now. Only some SKL tell cannot change..
Bro, care to tell where can I get it done in Senawang ? I tried to PM you but the msg din get through, Thanks
Bro do you know Senawang Light Industrial ? From the main road to Tampin, turn left at the Senawang Light Ind traffic light (after Petronas).
Once you turn in from traffic light then turn right and straight up about 100-150M on your left find Senawang Motor (Right side no shop)
