e46 318i 1.9 lot of prob...pls help
azhar1788
Bro,
Those are old issues (shadow error codes) Nothing to worry, the M43 engine is one of the cheapest and most reliable BMW engine and repairs are simple and cheap.
IMHO, I suggest you to use original air filter, check if the spark plug is original too / or any damage on the plug cable.
Last but not the least is to do a compression test worn pistons ring can be the reasons too.
azhar1788;855688 said:
hyee all my cousin car have this issue when scan using 1.4 scanner..
and the car cant go for 150kmh..when u reach at this speed then check engine worn up..showing check fuel system....
this car already done changing o2sensor, spark plug, coil and fuel pump less then a year....what should i do on this car..
plsss all the siffu help me... :stupid::stupid::stupid::stupid::stupid:
sounds like fuel starvation.....fuel filter?
anaksarawak;855693 said:
Bro,
,okey bro will change the plug cable....thankx bro
ya bro mmg this car feel lar heavy semacam bro,,,if u driving normal,,the car is ok,,but if a bit fast around 130>,,then check engine come,,show check fuel system....
First clear all the errors and drive the car.
If the alarm is consistent, it will return again.
The chances of all 4 HT cables failed at the same time is almost ZERO.
change fuel filter first and check the fuel pressure in the fuel rail.
jarance the error code come after push out the limit 140kmh MAX can go...
1st thing i do to change fuel filter,,second thing ill check the plug cable,
then ill update u all later....
thankx all...
thankx all...
almost a similar case with mine. but for me no need o wait until 140kmh... the error code (checkk fuel system) will come out n i live wih it for almost 1 year hehe, I did the same thing as u, change fuel filter, fuel regulator even fuel pump and etc hehehe....... lastly the problem solved by clean the MAF sensor with contact cleaner..... trouble free till now.. cheers..
​almost a similar case with mine. but for me no need o wait until 140kmh... the error code (checkk fuel system) will come out n i live wih it for almost 1 year hehe, I did the same thing as u, change fuel filter, fuel regulator even fuel pump and etc hehehe....... lastly the problem solved by clean the MAF sensor with contact cleaner..... trouble free till now.. cheers..
Cleaning a MAF sensor seem to be a small thing but it can cause a big issue if it not being taken care of, suspected symptom when MAF sensor dirty - lost power, engine warning light comes out, hunting rpm but these a just some guides before you go for big buck repair. It advisable to clean the MAF sensor once every 6 months, for those who never done that..trust me you'll feel the different after that.
I am driving e46, I have spend RM30k to repair the oil and water leak, but still having the same problem,when I go back to the workshop they advice me to change the engine,please advice how to overcome this problem.
Get second opinion from different workshop bro. List down in this forum what you have spent so far if you can. If those change are wer and tear items thats fine but 30k if big sum of money. You can get another BMW with bit more to top up, not just an engine. By the way what E46 you are driving?
