bilstein abs. & Eibach set-up.
manjit
Ok guys, need to find this out. Those with black bilstein abs. and eibach spring set-up, any idea what is the measured space(in cm or inch) between your wheel centre and arch centre. OK...for E36 only. thxmanjit
Depending on the condition of your bushes, balljoints, etc, expect a drop of 35mm-40mm from the standard height.
i don't have the standard reference, cause i bought it with lowered setup, and when i changed the abs. early this year, seems like the car looks rather standard than lowered. confirmed coil diametre differs from ori. By the way the wheel is on 17" setup.
