Bad expirience with water pump problem
suratsh
Who have expirience with water pump problem?Coz my ride today sounded krock....krock... at fan area.my aura suspected sound given by water pump.but no leak occour at water pump and floor not wet. Asking : :confused: -That is one of causes of Water pump problem or what?:confused: -What the cost for repair it?:confused: -So far no leak, what the causes if I just ignore the sound? :rolleyes: Any idea plz pass to me..... Thanx to all Bro.....
same problem here bro,taken to mech.found not water pump but belt tensioner and most top pulley bearing worn.
if it is water pump problem..u can c the water spray up ur engine hood...macam air pancut la itu macam...and got sounds "cittt cittt citt" or "krukk krukk krukk" like mouse -> tikus..hehehe...and ur temperature will increase when u stop ur car e.g traffic jamm sure die...:D
i think it is not a big problem..probably just fan bearing or ur fan belt slip..those might be causes the sounds...:D
Bro,water pump leaking are no any sound.like you asking ,pls check the the air -con compressor ,air con fan,if not found ,send to machanic for checking!!!
Thanxz too all Bro.....
Today i bring my ride to see Doctor the problem not done yet. My Doctor can't check due to problem gone when the engine hot Normal condition. But that happen only come when engine in cold condition only.
When is started at morning sound come out very noise and slowly gone when the engine warm.
That sounded given infornt of engine (Water pump/ Fan/ belting). all the parameter is okay no abnormal reading given and no vibration at the engine area
I think batter I bring to others specialist........
Sorry to hear what happened to your ride bro....anyways, saw that you're from terengganu from your avatar, any BMW specialist that you can recommend around K.T area? Cheers!
