Problem with my Business Unit
i was told that the PDC give the error sound even if only 1 sensor is spoil, in my case it was the broken wire, the bloody mouse got to the wire near the front bumper, i reconnect the wire and PDC is back working, so check the wire.
heng1028;539065 said:
my PDC is not working and how do i hunt down the broken transducer?
perhaps there are more than one broken transducers.
Should i just go and buy one transducer and try it out one by one?
are the side transducer different from the middle one as i read from the thread above that they have diferent range of distance.
anyone has this experiences to share?
thanks.
To find out if your PDC is working. switch on the ignition do not start the engine put to reverse gear and put your ear and listen to the sensors up close. the ones that are working will have a continuos ticking sound. if there is no ticking sound then it's faulty. to reconfirm connect to the one that is working.
heng1028;540266 said:
thanks bimmer i got it working by removing it and reconnect it back :p
save me RM400
You owe us teh tarik then......RM400 can buy many tt....
Does a pine of Paulaner considered as a TT.........:cheers:.........:cheers:..
